Advice on HPF/LPF adjustments on amp
1hawaii50
I just finished my install in my 07 Altima. I put MMC6500's in the front door with the tweeters flush-mounted in the top of the door panel. I put MMC690's in the rear deck. I have them powered with a Navone LOC running to a Kicker ZX650.4 amp. I have the gains turned all of the way down on the amp and already get decent volume from the speakers (I believe the Navone LOC is set at 9 volts). I am finding, however, that if I attempt to turn up the gains at all, the bass gets really easily distorted. I have the front crossovers set to -3 for the tweeters. Both the fronts and the rears will distort from the bass with very little input from the gain controls. I have the HPF/LPF's turned off on the amp. Do I need to set the HPF's? If so, where is a good starting point?
Sorry for the noob questions...I'm still trying to figure it all out. I've gained a wealth of knowledge from this site already.
Thanks in advance.
Thanks in advance.
Post edited by 1hawaii50 on
Do you have the bass boost on? If so, turn it off. Even with a 9 volt LOC, your speakers shouldnt be distorting that soon.polkaudio sound quality competitor since 2005
Bass boost is off, bass and treble controls on H/U are set to "0", gain controls on amp are at lowest setting (full counter-clockwise), and the HPF/LPF switch on the amp is turned off (full signal to speakers). I double checked all of my connections again to make sure I didn't have any speaker polarity crossed, and everything checks out wiring-wise, so speakers should not be out of phase. On the MMC690's I've got the black wire w/white stripe as the +, and the black wire as the -, on the MMC6500's, I've got the red wire/s as the +, and the black wire/s as the -. I also double checked the speaker polarity at the amp, and they are correct.
Stupid question, but are you running the speaker-level outputs into the line-level amp inputs? That's what it sounds like...TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
the navone loc has a 2:1 voltage divider meaning if you have 10v in you get 5v out,so the output depends on the input. with the gains turned to minimum you only need 5 volts to drive that amp with the sensitivity set to low. if you have a test cd and a meter see if you can measure the output because you might be overdriving the amp and if you are just reduce your volume. i was just wondering, why didnt you just run the radio output directly to the amp? you can just solder rca ends to the speaker outputs of the radio switch the sensitivity to high on the amp and run it like that.kenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
I am using the factory H/U (non-bose), into a Navone LOC with the voltage adjustments of the LOC set to MAX (9.5v, I believe). I used the LOC instead of the line level inputs as I was under the impression that I would get a much better signal that way. The LOC I am using is the Navone NE-774v.
The only real benefit to running the LOC is if it has a line driver on it. Bumping the output voltage up a bunch will greatly reduce the noise floor.polkaudio sound quality competitor since 2005
Should I turn on the HPF on the amp? What setting should I begin with/what is the lowest range the MMC6500's can handle efficiently without distortion?
