Pics of HT so far...
DannyD
DannyD Posts: 133
edited June 2008 in Speakers
So I just wanted to show my setup and get some opinions and or advice on the speaker placements and such. How bad is it to have the sub beside sliding door windows and where else could I possibly put it?
Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner
Post edited by DannyD on
  • zingo
    zingo Posts: 11,258
    edited June 2008
    Sweet sassy mulassy! I like the blue lights. How did you do those? What about putting the sub between the chair and the component rack?
  • Face
    Face Posts: 14,340
    edited June 2008
    Other than the toe looking a little excessive, it looks great. I like the blue lighting too.
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2008
    DannyD wrote: »
    Experiment. It actually looks similar to my setup.
    Suggestions:
    1. Move equipment rack to left wall.
    2. Move left speaker and TV to the left. Leave right speaker as is. Center TV between speakers.
    3. Put sub in front of TV, and put center channel on top. Put inclined door stops under center to incline it upward towards seating area.
    4. Put acoustic treatment on bare walls to reduce reflections. Either foam or panels will work.
    Once you have it optimized then realize you need to upgrade.
    1. Buy 4 LSi15s.
    2. Buy external amp.
    3. repeat process
  • Face
    Face Posts: 14,340
    edited June 2008
    BlueFox wrote: »
    Besides looking tacky, it doesn't sound like a good idea. Subs usually do best near a wall or corner, especially down firing.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited June 2008
    I don't think your subwoofer is big enough. The rest looks like crap with that tiny sub. ;)
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2008
    Love the lighting and I agree with Face by not putting the sub in front of the TV. And 4 LSi15s would be a waste. Amp up the 10s to get their full potential when you feel you're ready for seperates, until then play around with "speaker placement" and enjoy.
  • amulford
    amulford Posts: 5,020
    edited June 2008
    Looks good. I like the lights. Toe in is a little much. You might wanna straighten them back a little...
  • engtaz
    engtaz Posts: 7,664
    edited June 2008
    Looks great. Love the blue.
    Congrats,
    engtaz
    engtaz
  • DannyD
    DannyD Posts: 133
    edited June 2008
    The lights are strip led's from your local Ikea. With the push pf a button you can change from 7 different colors. Here is a link if anyone is interested. http://www.ikea.com/us/en/catalog/products/50119407
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • amulford
    edited June 2008
    I like them, it's a nice accent. Thanks for the link.
  • zx_toth
    zx_toth Posts: 417
    edited June 2008
    According to the THX website the toe in should be 45 degrees inward if your main seating arrangement is such that the 'imaginary' line created from the speaker hits your main seat to create a triangle. Some literature suggests the imaginary line from the same side front speaker should lead to your same side ear ....
    http://www.thx.com/home/setup/speakers/front.html
    It looks like your toe in is too aggressive and the lines of intersection cross before they reach your primary listener. This angle is variable of course if your seating area is further away, thus requiring a smaller angle (say 30- 40 degrees). A few simple measurements should allow you to figure this out.
    Even without any upgrades you can UPGRADE the sound by being smart with optimization!
    Good luck.
    Zsolt
  • DannyD
    DannyD Posts: 133
    edited June 2008
    Face wrote: »
    The pictures make the toe in look more excessive than they really are in person. When in the seated position they're pointed right at you. The problem is my couch cannot go much farther back so the toe looks excessive. Iv'e had them pointed straight for months now. Just recently toed them in to experiment. I think the real problem is they are too close togther. For me to move my audiorack would mean to change to all new and longer cables. There's not enough slack...rookie mistake.:eek:
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • DannyD
    DannyD Posts: 133
    edited June 2008
    zingo wrote: »
    I think for now that's my only option. I wanted to try that for some time now but I didn't think it made sense to have it facing the window doors. My understanding is bass is nondirectional so it really shoudn't matter much right?:confused:
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • Ricardo
    Ricardo Posts: 10,636
    edited June 2008
    Just reduce the toe in as others have said; maybe place speakers a little further apart from the TV....but not a must; this is just personal peference.
    Don't get yourself caught in upgradeitis...what you have to power those 10's is good enough. Just sit back and enjoy. And yes, the leds look great; is white/natural one of the 7 colors?
    SOPA
  • DannyD
    DannyD Posts: 133
    edited June 2008
    Ricardo wrote: »
    White is one of the colours but it's not a true white that you may be thinking of. It has a very slight green tinge to it. The good news is Ikea sells the exact same led strips in ONLY white which is more of a true white. I use those ones for my Aquos upstairs. If you click the link earlier in this thread it will take to the Ikea page and just choose the white ones instead of multicolor.;)
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
  • hockeyboy
    hockeyboy Posts: 1,428
    edited June 2008
    Is that a Universal remote under your Rambo SD disc? What are all the remotes for? Nice setup though, I love that sub!
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • DannyD
    DannyD Posts: 133
    edited June 2008
    hockeyboy wrote: »
    No it's not but I deperately need one. I have 4 remotes in circulation. 1 for my receiver, 1 for my DVD player, 1 for my TV and a little guy for my sub. Looking to get a Logitech harmony remote.
    Fronts: RTI10's
    Center: CSIA6
    Rears: RTIA3's
    Blu-Ray: PS3
    Monster Cables
