Rear Surround Recommendations
mldennison
mldennison Posts: 307
edited June 2008 in Speakers
I am looking for some rear surrounds to round out my home theater. I have a Surroundbar for the fronts and just need some extra ambiance. For this setup, I really need something small as there is not much room on the walls for these. I was thinking about the RM101 series:
http://www.polkaudio.com/homeaudio/products/individual/surround/rm101/
and just wanted to see if anyone had any other recommendations of something similar.
Thanks,
Mike
Post edited by mldennison on
    tonyb Posts: 33,072
    edited June 2008
    I'm a bit confused......normal for me these days.....what your asking doesn't jive with your sig.Is this for a second system? The rm's are ok for smaller rooms,I mean smaller rooms.How big of a room are you looking for surrounds?Bedroom maybe?
  • mldennison
    edited June 2008
    Sorry, I should have been more clear. The room is large (15x18), and is used for our home theater and some light music listening. I already have a Surroundbar and a Sub, but I wanted to add a little more depth to the soundstage by putting in 2 rear speakers. Unfortunately, because of the amount of space on the wall, I need something physically small. I realize the RM series is not the most powerful thing out there, but what I am really looking for is just a little bit of add-on to what I already have, so it does not need to be that powerful.
    I am basically just looking for anything else that people have used for rear surrounds which are small and they had success with...
