misinformed
jammer4444
jammer4444 Posts: 36
Fellas:
I am currently in new HT construction. Being very novice at what is required for HT i asked a "friend" what kind of wire I needed for subwoofer. He advised to run RG6 and then purchase adaptor for ends. I ran it in three different places where i may put a sub. I have since drywalled and went to go buy the adaptor and dude at Circuit said that RG6 is for video not audio and I need to run digital audio type cable.
Can someone tell me which wire is the proper one for subs. I'd rather not take down drywall, but I will, if its best.
thanks, jammer
Post edited by jammer4444 on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2008
    The coax is fine for your sub.
    Ben
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2008
    LOL yes Coax is fine for your sub. I use 3 pairs for a whole house system to send a source to an amp in a closet at home. Never an issue, just fine.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • disneyjoe7
    edited June 2008
    If anything you're "Misinformed" by CC... But that shouldn't be much of a surprise ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • jammer4444
    edited June 2008
    OK thx a lot, pheww, I sure wasn't looking forward to pulling off drywall. CC dude was pushing Monster THX Sub cable. What type of connector do I need for the ends??
  • Face
    Face Posts: 14,340
    edited June 2008
    Either or is fine. Just don't buy anything from Monster.
  • ben62670
    edited June 2008
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=091-1060
    These will work fine. Buy an extra just in case. Read the reviews you will get a chuckle.
    Ben
    Ben
  • disneyjoe7
    edited June 2008
    http://www.hedtechcoax.com/servlet/the-30/rg6-compression-adapters-coaxial/Detail
    I also found these, I used something like them for Audioquest.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    edited June 2008
    Do you need the compression tool for those?
    Ben
    Ben
  • disneyjoe7
    edited June 2008
    Ben,
    The ones from AudioQuest where a push on connector which has teeth that allow it to go in one way, and not be pulled out. I assume those which I linked to are similar. You just need to cut cable to correctly to setup, but it would of been the same if I used a crimper style end instead.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    edited June 2008
    Cool AQ stuff is solid except those flimsy nanners they used on some of their cables.
    Ben
  • Polkitup2
    Polkitup2 Posts: 1,641
    edited June 2008
    I run RG6 in-wall for my sub and it works fine.
  • Rivrrat
    Rivrrat Posts: 2,101
    edited June 2008
    The digital coaxial cable I got from Monoprice for my sub is built from rg6 cable.
    My equipment sig felt inadequate and deleted itself.
  • jammer4444
    edited June 2008
    thx for the replies. I realize my minor problem was a no brainer for you guys but you saved me a lot of unnecessary work. thx again.
    CC "expert" had me convinced I made a mistake. Now I'm debating going back there to put "dumb ****" in his place!
  • dave shepard
    dave shepard Posts: 1,334
    edited June 2008
    jammer4444 wrote: »
    Sounds like he's already in his place.....a dumb-**** place.
    So your gonna have to think of something differant perhaps reminding him that is why he is where he is.
