Local Pick-up Only Rocket RS750 Sig, RS550 MK II, RSC 200, XCD-88
Terrax
Terrax Posts: 483
edited June 2008 in For Sale (FS) Classifieds
Up for sell:
A pair of Rocket 750 Sig's (Ebony) in excellent condition with Risers included. = $500.00 - Original owner 10/05
Local Only
Specs:
Multi-way, five-driver direct-radiating system, vented enclosure with two rear-firing flared ports
Drivers: Vifa Ring Radiator tweeter, four custom 5.25" long-throw aluminum cone woofers
Crossover: Tweeter at 3.8 kHz, progressive array, variable slope
Frequency Response: 38 Hz to 20 KHz (± 3 dB)
Impedance: 6 Ohms nominal
Efficiency: 88 dB (@ 1 watt / 1 meter)
Dimensions: 37.5" H x 15.5" D x 9" W
Weight: 56 lbs each
A pair of Rocket 550 MK II's (Ebony) with Risers included = $400.00 - Original owner 10/05. These were shipped to me with one of the mid-bass driver surrounds separated from the basket about 4" around. I merely re-glued the surround back to the basket and it has performed as it should with no problems since. I was shipped a spare driver (also included). Which is very easy to exchange out, if you can solder. Just haven't seen the need to do so yet. Otherwise... in perfect working order, no scuffs, nicks or mars in the finish other than very slight fissuring in the veneer. Local Only
Specs:
Two way, three driver direct-radiating system, vented enclosure with two rear-firing flared ports
Drivers: Vifa Ring Radiator tweeter, two custom 6.5" long-throw aluminum cone woofers
Crossover: 3.8 kHz, 3rd-order alignment
Frequency Response: 40 Hz to 20 KHz (± 3 dB)
Dimensions: 35.25" H x 15.5" D x 9.5" W
Weight: 55 lbs each
Rocket RSC200 (Ebony) in excellent condition = $350.00 - Original owner 10/05
Local Only
Specs:
Three way, four driver direct-radiating system, vented enclosure with rear-firing flared ports
Drivers: Vifa Ring Radiator tweeter, one custom 4" midrange and two custom 6.5" long-throw aluminum cone woofers
Crossover: 580 Hz and 3.0 kHz
Frequency Response: 44 Hz to 20 KHz (± 3 dB)
Impedance: 8 Ohms nominal
Efficiency: 89 dB (@ 1 watt / 1 meter)
Video Shielding: Yes
Dimensions: 12" H x 10.5" D x 25 7/16" W
Weight: 46 lbs
Onix XCD-88 = $175.00 + shipping - Original owner 10/05
Can be shipped, Shipping would be from Nebo, North Carolina 28761
Specs:
Burr-Brown 1732 24-bit/96kHz DAC
HDCD decoding chip
CD-R & CD-RW playback
S/N ratio (WTD): 104dB
Channel Seperation: (1KHz): > 96dB
Two digital outputs; 1 x coaxial and 1 x optical
Standard analog output
Philips CDM-12.1 transport controlled by a CD-7mkII servo
The OPA 2604 op amps are used for the output stage and low pass filtering
Thick brushed-aluminum front plate and solid chassis
Full remote-control operation
High quality remote control
Easily readable and dimmable florescent display
Detachable power cord
110V/220V Switchable
Shipping weight: 18lbs
I do not have the original boxes but I do have the cloth socks, manuals, floor spikes.
Post edited by Terrax on
