which surrounds to get?
edited June 2008 in Speakers
i've got a set of rti12's in a 2.0 setup right now.
want to get to a 4.0 setup.
would you recommend the fxia6 or the rtia3?
the surrounds will be mounted on stands behind a couch.
i'm leaning towards the rtia3 thinking that if i decide to use the speakers somewhere else (like for front mains in an bedroom setup), that they're a better stand alone speaker than the fxia6.
plus, the rtia3's are cheaper than the fxia6.
is there any reason to choose the fxia6 over the rtia3?
    edited June 2008
    The FXi A6 is designed to be a surround speaker. It uses Bipole/Dipole to give a better surround effects. I have the RTi A3 and I’ve never had a problem using them as surround speakers but using the FXi A6 would sound better. If you want to use them as stand alones one day then I would suggest going with the RTi A3. It will give you more flexibility in the future.
    7.1 HOME THEATER:
    Center: CSi3
    Front: RTi10
    Surround: RTi A3
    Rear Surround: RTi4
    Subwoofer: Mirage Omni S10
    TV: Sharp Aquos 42" 1080p LCD
    Receiver: Onkyo TX-SR805
    Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3
Welcome!
Welcome!
