Set Up Advise Please
CallingMrBenzo
CallingMrBenzo Posts: 34
edited June 2008 in Speakers
i have been fiddling with my receiver ever since i got it and i want to know what cut off frequencies i should have
i am running
polk csr center
polk r300 fronts
polk r150 rears
w/onkyo sr 606
and a logitech computer sub (filler for now)
they are set now to
center 80hz
fronts 80hz
rears 100hz
sub 120hz
the audessy set up had the center/fronts set to full band
with the double bass feature set to off...
please help me out:)
My College Setup
TV: Mitsubishi WD60735
Gear: Logitech Harmony Xbox Remote
Toshiba HD-A3, Samsung BD-P1500
Sony SCD-CE595, Direct TV HD DVR, Xbox 360
Receiver: Onkyo TX -SR 606
Speakers: JBL S Center, JBL S310,Polk R300 R
Sub: Kicker L5 in ported box
Pics --> http://www.blu-ray.com/community/gallery.php?member=CallingMrBenzo
Post edited by CallingMrBenzo on
  • CallingMrBenzo
    edited June 2008
    bump bump please.....i know some of you people out there own these polks!!!
    My College Setup
  • engtaz
    engtaz Posts: 7,664
    edited June 2008
    What model receiver do you have? I don't see a problem with your settings but you should experiment with the settings to see what you like. Have you calibrated you speakers? Did you use a SPL meter?
    Good Luck,
    engtaz
    engtaz
  • devani
    devani Posts: 1,497
    edited June 2008
    he said onkyo 606...he mentioned using audessy set up but not SPL meter...
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • CallingMrBenzo
    edited June 2008
    no i dont have one yet...
    but you guys think those frequency cut offs are alright?
    My College Setup
  • engtaz
    engtaz Posts: 7,664
    edited June 2008
    Yes they are. get a SPL meter and then you will truly dial in your system. Set them all to full and try the sub at 100 then try it at 80 and see how you like it for both music and HT. Thanks devani, I was looking at the speakers and missed the Onkyo.
    engtaz
    engtaz
  • CallingMrBenzo
    edited June 2008
    set all speakers to full so no cut off frequencies?
    then just mess with the sub setting?
    My College Setup
