SR6500 on an Accord
Kinetic
guys im about to buy my SR6500
are these going to fit my Accord 2000?
I already check on crutchfield but it says rear deck just the SR5250 fits on the kick panel.
what should i do?
what should i do?
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Polk Audio SR 6500
G35
Post edited by Kinetic on
I cant say for sure on a 2000 model but they will fit on the next generation only with some cutting of the door and 1" or more in spacers. The 5250's will drop right in tho.polkaudio sound quality competitor since 2005
what would you do Mac?
buy the 6500 or the 5250 for the accord...
i already take meassueres, and i think i can make the 6500 fitZ
Polk Audio SR 6500
G35
KnuKonceptz MKS Kable -
and also
should I invert the polarity on the tweeters?
i have the tweets on the dashboard, next to the windshieldZ
Polk Audio SR 6500
G35
Cant go wrong with either. I used the 5250's last season and they were awesome. Spot on imaging. Im using the 6500's now and am enjoying the fatter midbass but theyre harder to get the imaging focused up just right.
If you can fit them, Id go with the 6500's but if not I would in no way hesitate for a heartbeat to use the 5250's. Im telling ya tho, if you go with the 6500's plan on doing a little hacking. Those babies are a little fat around the basket.
As far as tweeter polarity - yes. If youre not going to use time alignment, swapping the polarity does help in the Accords case.polkaudio sound quality competitor since 2005
thanks a lot Mac
im doing the time aligment, but now with the bi-amp and the 3 way on the HU, im thinking thats going to do a huge change in my SQ.
also I ordered some new rca and speaker wire from knukonceptz
i will post some pics on 3 days, wish me luck...Z
Polk Audio SR 6500
G35
