Rewiring cartridge to headshell
Fongolio
Fongolio Posts: 3,516
edited June 2008 in 2 Channel Audio
I am rewiring a cartridge to headshell. The cartridge is mounted in a headshell and is standard half inch and is marked for red white green blue. The headshell connections are not. I have 3 turntables with half inch cartridges and all three are wired differently. This can't be correct. Common sense says the headshell should be wired identical to the cartridge such that if the wires weren't bunched the red would run in a straight line to the headshell connection as would white blue and green. The particular headshell I'm rewiring has them crossing over. With the stylus pointing down the top right wire is red top left white etc. Then looking at the connectors on the headshell red is top right white top left. This seems to me to be crossing them over. So the question is what is the correct way to wire the headshell? Thanks for any input.
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Post edited by Fongolio on
    billbillw Posts: 7,538
    edited June 2008
    Don't worry about whether they crossover or not. Just worry about matching the correct R+, L+ and grounds to the tonearm, which in turn matches the RCA outputs. Use a continuity meter to check.
    Cartridge manufacturers didn't always do things the same, just as different TT/tonearm manufacturers often did things differently.
