Hate annoying popup ads?
Strong Bad
Strong Bad Posts: 4,278
I just bought some software called "AdSubtract" and it works very well at stopping those pain in the **** popup windows & ads when surfing the web.
$20.00 at Best Buy. Very well worth it!!! :D
John
No excuses!
    F1nut Posts: 51,686
    edited December 2002
    Great, thanks for the info!
  • jrausch
    jrausch Posts: 510
    I use Smart Explorer which has a lot of very cool features built in one of wiich is a nice pop-up blocker, even the hack sites can't knock this one down. You can group all you favorite web sites into a single group button and it will pull up all of them at once. www.smarteque.com
    "The only way to get rid of a temptation is to yield to it."
  • Frank Z
    Frank Z Posts: 5,860
    I downloaded Ad-Aware from www.lavasoft.com, it was free. I run it once or twice a week to keep the pop-up's to a minimum.
    F1nut Posts: 51,686
    Frank,
    I agree, Ad-Aware works.
  • STUFFMD
    STUFFMD Posts: 381
    Yes but can you turn it off when you need to????.....I have some sites that use pop-up based programs to function, that I need for work????
    Thanks , StuffMD
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
    F1nut Posts: 51,686
    From what I can tell the Ad-Aware doesn't stop them until you run the program and then delete whatever it detects.
  • Strong Bad
    AdSubtract has a custom site filter. You add the website to the filter and tell it whether to filter out only popups, ads, both or neither.
    This program works very well!
    John
    No excuses!
  • STUFFMD
    STUFFMD Posts: 381
    Sounds reasonable...Thanks Guys.
    Peace StuffMD
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    PS2/Gamecube
