Ohm problem with old speakers
PaPa Honey
This is my first post. I need help with my Polk SDA-2 speakers that I purchased in 1985. Until now, I have been using an Onkyo TX-85 to drive these 2 speakers and they have worked great for 23 years.
I decided to upgrade to a 7.1 system using wires I installed when I built my house in 1986. I purchased an Onkyo TX-SR605 and Polk RM6880 5.1 speaker system. The speakers haven't arrived yet, but I connected the TX-SR605 to the SDA-2 speakers to see how it sounded.
It sounded great but after a period of time evidently the amp protection circuit activated. The Polk SDA-2 speakers are rated at 4 ohms. After a cool down period of time, the amp started working again.
Is there anything I can do to make the system work that I have purchased, or do I have to upgrade to a stronger amp? If I have to upgrade, what should I buy? I would like to stay with Onkyo because for 23 years I have been pleased with the performance.
Post edited by PaPa Honey on
You'll have to return the 605 and get a model with pre-amp outs(705 and above I believe), and buy a external amp for the SDA's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yup, they are drawing too much and your receiver doesn't like it. (Most don't like SDAs) Pre-out the receiver to a separate amp, or just get a multi channel amp and preamp combo.
Face And zingo,
Thanks for the quick reply!! I am thinking about the Polk SR805. Do either of you have a suggestion for a seperate amp for the SDA-2 speakers?
Thanks again for the help -
Check out the amplifier section of Audiogon and look for something in your budget.
http://buy0.audiogon.com/cgia/fsb.pl?ampstran&1&ctg&st1"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
