Looking for some understanding of the IC.
fbm211
Hi again everyone.Ive spent a-lot of time reading up on all the xover mods and interconnect cable upgrading and really want to upgrade my IC.First of all what is the purpose of the large(top) blade.When I was trying to figure out why my right stereo driver wasnt working I was told by some of you to only connect the female disconnect from the xover to the bottom (smaller) blade connection inside the cabinet.Its that way on both speakers.The large blade isnt connected to anything so Im just wondering if I have it right.The SDAs are 2Bs.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
If you have the pin/pin [edit- that should say blade/blade] connector, and I think you do, only the lower pin is used. The top blade has no use in the circuit.The world is full of answers, some are right and some are wrong. - Neil Young
I believe you mean blade/blade, http://www.polkaudio.com/forums/attachment.php?attachmentid=26674&d=1186345413
You are correct by saying the top blade is not in the circuit though."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Yes, I do mean blade/blade. Still on my first cup of coffee.The world is full of answers, some are right and some are wrong. - Neil Young
Well thats easy enough.Parts express has some nice premium binding posts with male-disconnect tabs.A pair of those and a nice 12 guage cable from signal with vampire spades should do.SDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Ah heck Ill just order the wire and spades and make my own.I just got some WBT silver solder and a iron so I may as well put it to use.SDA-2BTL with custom IC
