REL Speakon connecter question
brabus420
I just acquired a REL Strata II and REL Stentor II recently and realized I forgot to pick up the speakon connector cable that comes with it from the previous owner. Turns out he threw them away when I did finally remember and contacted him.
So now I'm in need of two cables. I know signal cables makes this for $90 but I am an amatuer DYI'er and would like to make the cable myself. I started looking around for the connector and it turns out there are multiple Speakon cable connectors and I can't tell from the pics which speakon cable model I need to use. Can someone point me in the right direction and tell me which model Speakon I need? Thanks!
Michael
NORTH of 60° -
Thanks. It looks like it is the NL4FX.
Not sure what that is but hope it helps. If the NL4FX is applicable, let me know as I found a document on this.Michael
NORTH of 60° -
Actually, after looking at the pics, it doesn't seem to match. The connector on the subwoofer, is female an has three pin female slots in a triangular orientation. So I need the male end connector to match.
