SDA-SRS vs. LSi15
audioblonde
I searched,no info found.I am interested in a pair of SDA-SRS that are for sale.I have a pair of LSi15,run with 300wpc amp.If anyone is well familiar with both,please can you opine on the 2 in a comparison?My listening room is well damped,12x20x8.Many thanks! p.s. may be worth mentioning that nearly 100 per cent of my listening is acoustic fare,the likes of 'bebop',such as Gene Harris,Oscar Peterson,RayBrown,et al,etcetera.
Post edited by audioblonde on
I went to Jazz bar day after oscar peterson died...they were playing his tunes for his contribution....+1 for sda'sVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
I just picked up a pair of the sda srs's and they are sweeeeeeeeeeeeeet! I bet you will like them as well!
this is almost apples to oranges.
I side by sided my SDA 1B's and the LSi and preferred the LSi, thats not to say I dont have a warm spot in my heart for SDA's
if you got a bead on SRS's, then you need to get them and let your ears evaluate it. The differences, as well as the sound from the SDA SRS's, is just something you have to experience, words just won't do it.
from a general standpoint, I like the high's better in the LSi's. I give the edge to LSi's in the detail department, but width of soundstage and overall presence will most definitly go to the SRS (hence the "you have to experience it" aspect of my argument)
the big SDA's (and some smaller ones for that matter) should always be on the audio enthusiasts list of speakers to get alot of ear time onLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Don't listen to ohskigod...he's been drummed out of the cult :eek:
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
yeah yeahLiving Room 2 Channel -
