Tweeter Polarity on the SL3000s
dcmeigs
dcmeigs Posts: 708
edited June 2008 in Vintage Speakers
I have some SL3000s here. There is no + scratched in the plastic or red dot on these. It does have the small/large terminal setup.
What is correct convention for the + terminal? Small or Large?
The world is full of answers, some are right and some are wrong. - Neil Young
Post edited by dcmeigs on
    F1nut Posts: 51,700
    edited May 2008
    Small
  • dcmeigs
    dcmeigs Posts: 708
    edited May 2008
    Thanks F1Nut. At 3 minutes you beat the fire & rescue and pizza delivery.
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited June 2008
    When I called polk last year, they thought the wide terminal was positive.
  • zingo
    zingo Posts: 11,258
    edited June 2008
    It doesn't matter which terminal is which... :p
    F1nut Posts: 51,700
    edited June 2008
    That's not exactly true as Polk terminated the positive wire with a small connector to match the small blade on the tweeter and the negative wire with a large connector to match the large blade on the tweeter. Therefore, making sure that the polarity is kept correct thru out the wiring harness.
