My Proposed Setup/Upgrades, Opinions?
jpolz
Currently I'm running a 2.1 setup (see sig). After owning my LSi15's for 2 months I've realized that my STR-DE1075 just can't drive them like it should. I don't listen to high volumes, but I am definitely looking for that punch that you get when a speaker has enough power. I'm getting ready to pull the trigger on some upgrades and wanted to see what the general consensus was.
Sony AVR, out.
Emotiva LPA-1 & Onkyo 705, in.
The LSi15's will be bi-amped to the LPA-1 and I plan on using the AVR to power a 2 sets of speakers in other rooms.
Considering the Onkyo can be had for ~$500 it should be a pretty killer setup for roughly $1K.
Sony AVR, out.
Mains: Polk LSi15
Pre/Pro: Yamaha RX-V663
Amplifier: Emotiva LPA-1
Subwoofer: KLH ASW8-120b
Post edited by jpolz on
Is this for music only or HT as well? If it is for music only then, might as well do away with the Onkyo avr as well and get a dedicated preamp. It will sound lots better than using an avr as a preamp guaranteed.
Both.
Eventually I plan to add the LSiC & LSiFXs to complete the system.Mains: Polk LSi15
Subwoofer: KLH ASW8-120b -
Agreed. Get yourself a used LMC-1 for about $300 - $350 to mate with the LPA-1. You'll be much better off for music and HT. Plus, you can pocket the savings.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
