b&k st 125.3 to SVS
paymontna
paymontna Posts: 188
Is there any way to rig my b&k st 125.3 (specs listed below) to power a SVS 16-46 CS or 20-39 CS–Plus. I am on a budget of about $700. I do have a relatively large room @ roughly 3,400 cu ft. The B&K amp is currently being used to bi-amp my Lsi-9's and LsiC with negligible improvement of performance. The ideal set-up would be to use my b&k st 125.5 to power the 5 standard speakers, use two channels to power (roughly 370 rms watts @ 4 0hms) the SVS and use the other channel to power the a second center channel. I think this set up would add the most "presence" to my system per dollar. The old 150 watt Yamaha dual 8" Servo is the current weak link in my system.
b&k st 125.3
Number Of Channels: 3
Bridgeable: Not Bridgeable
Audio SNR: 90 dB
Frequency Response: 5 Hz - 45 kHz
RMS Power at 4 Ohms: 185 W
RMS Power at 8 Ohms: 125 W
THD (Total Harmonic Distortion): 0.09 %
No. of Speaker Outputs: 3 Speakers
And I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
Post edited by paymontna on
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2008
    Since the amp is not bridgeable, you'll only be able to use one channel on the SVS. I think you'll get pretty decent performance w/185w @ 4 ohm on the NSD model, but are a tad underpowered for the Plus. However, that's an SVS call and you should ping sales or tech support the question. I've seen them tell folks that 150 watts is plenty for most rooms.
    I'm sure you can get by until you can put something a bit more beefy on it.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    LRKSFAG wrote: »
    Brother's great, I top you and I are also top-Jin top。NSKTIMKENSKF****
    Wow you guys are getting lazy, you can't even put together a coherent sentence anymore? Reported.
