Anyone use Atriums inside for HT?
powers20
powers20 Posts: 21
edited May 2008 in Speakers
I have RTI4s front, CSI3 center, and need to upgrade surround back and side pairs. I am looking at either FXI3 side Atrium 45 back, or possibly Monitor 30 side Atrium 45 back. Anyone who has opinions on this I would appreciate help deciding. Running off 110wpc Yammie RXV-1400. Velodyne sub. Help, I'm going mad!
Front RTI4s
Center CSI3
Velodyne ULD-18 Sub
Pioneer DV-563A Dvd, SACD, DVD audio player
Sony CDP-CX355 300 disc CD player
Technics SL-7 turntable
Yamaha RX-V1400 A/V Reciever
Dish Network DVR
Playstation 2 and 3 both optical out
Sony Wega 34" Widescreen CRT HDTV
Post edited by powers20 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    I would strongly suggest sticking with the RTI lineup. You could upgrade you fronts, and move your 4's back.
    Ben
    Ben
  • hockeyboy
    hockeyboy Posts: 1,428
    edited May 2008
    Atriums are technically outdoor speakers, and I would not recommend using them IMO. Of course, you can get them wet so if you spill your beer there is no problem! Move your 4's back and get some 6's for the front.
    That will give you a fairly sweet 5 channel. IMO don't waste your money on 7 channel unless you have a very big room. Save the coin, and start savin' for an amp upgrade. The move to separates is where you will want to be to make it to the next rung on the ladder, and you will see immediate impact with the 6's.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
