Need Advice and Suggestions for SR6500 Install
Ivorytooth
Ivorytooth Posts: 14
edited June 2008 in Car Audio & Electronics
Hi,
I am new to Club Polk and need a bit of help. I am not very knowledgeable about car audio.
I was given some brand new Polk SR6500 in the box last year as a gift and I need to figure out what car to buy for them. :) They're just sitting in the back room in the box begging to be used.
Right now I have a 1998 Ford Escort with over 200k on it, so I am in need of a new car soon. I looked to see if they would fit in the car I have and they won't without some work.
I have a Alpine CDA-7995 as a head unit and a Alpine MRV-F540 for an amp.
I am not looking for any complex system, just the HU and the amp with these speakers.
My question is what car would the speakers be easiest to install and sound good. My main parameters would be a smaller car that is good on gas.
What would be a good car of that type to install these speakers in? I would likely install myself, so I don't want to do something elaborate just to get them to fit.
I was thinking of a Ford Focus or a Honda Fit. Could those work in these two cars?
Thanks in advance!!!
Post edited by Ivorytooth on
  • exalted512
    exalted512 Posts: 10,734
    edited May 2008
    Basing the purchase of a car on the speakers you have is borderline insane.
    -Cody
  • Ivorytooth
    edited May 2008
    exalted512 wrote: »
    -Cody
    Yup, but if I can do it, I want to. :)
    I am not disregarding any other factors in buying a car, but I would like to know what my choices are to start. If I can't find a new car that these are fairly easy to install within my parameters, then I would have to give my gift back to the giver as I would not feel comfortable selling a gift.
    I am hoping there are people here that have installed these in smaller cars and that I would be able to benefit from their experiences.
  • eloplayspolo
    eloplayspolo Posts: 1,117
    edited May 2008
    if u want something good on gas... go with a corolla or a civic (maybe even a fit). Speakers will fit into all 3 of those... with a little modification. for my MOMOs which i think a few peeps mentioned they had a larger basket.... i had to trim a little of the door... but it was like 2 mins of work. just scary cutting a car thats less than a week old.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • MacLeod
    MacLeod Posts: 14,358
    edited May 2008
    Nissan Altima is the easiest to install. The doors take 6.5" speakers and wont require any cutting and there is room in either the dash or the A pillars for the tweeters. Also the kick panels are large and flat and dont have any fuse blocks or other crap to get in the way should you ever want to mount speakers there. Best of all, the Altima is a great car.
  • Kinetic
    Kinetic Posts: 437
    edited May 2008
    Honda Accord, Honda Civic, Nissan Altima...
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • Ivorytooth
    edited May 2008
    I have been doing some car research and I am leaning towards the 2009 Honda Fit. I won't be buying a car until this fall so I am hoping to snag a 2009 model of something.
    I like the Fit because of the space along with the gas mileage. It got great ratings too. I am a competitive archer and travel many tournaments all over the country. The Fit has room for all my archery equipment. I am also big into fly fishing and I will have room for that too.
    I don't like the fact I may have to buy it with the stock stereo system. That is the first thing going out I believe. :D
    I have until September or so and I will keep doing research.
    Thanks for the help so far! I really like the looks of the Altima, but it isn't going to be my first choice. If I didn't need space for bow cases, flyrods etc., then I would be digging it. :)
  • Kinetic
    Kinetic Posts: 437
    edited May 2008
    Ivorytooth wrote: »
    as part of the honda fan club, i know for sure that the next generation of fit will be available soon, here in mexico will be available on september, im not sure when in the states, but you should wait for sure, to get the new one..
    Z
    Polk Audio SR 6500
    G35
  • addikt
    addikt Posts: 36
    edited May 2008
    nissan skyline r34 gtr do it u know u want 2 or the new (pontiac el camino) or whatever u call it over there 2 doors and a tub to load crap into like a truck but smaller basicly a holden ute exported to over there the polk sr6500s work great in mine!!!
  • Kinetic
    Kinetic Posts: 437
    edited May 2008
    what about the sports version?
    Z
    Polk Audio SR 6500
    G35
  • MacLeod
    edited May 2008
    The Scion Xb is the best SQ platform for a car. It has 3" mids in the dash, tweeters in the A pillars and 6.5" mids in the doors STOCK! Plus, the windshield is flat as opposed to curved back toward you and the roof seems like its 10' tall. You put some quality gear in these stock speaker locations and youll sound very good right out of the box! But the trade off is you have to drive around town in an Xb.
  • eloplayspolo
    edited May 2008
    bash scions alllll u want.... still the best car u can get quality wise... Toyota will run forever.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • MacLeod
    edited May 2008
    Ummm. OK.
    Toyotas will run forever. The Xb is still the ugliest thing on the road and sucks to drive with its whole 1.3 liter engine.
  • Kinetic
    Kinetic Posts: 437
    edited May 2008
    Did anyone know if polk are going to replace the SR 6500?
    im ready to buy them, but it seems to be a low stock on the internet
    Z
    Polk Audio SR 6500
    G35
  • eloplayspolo
    edited May 2008
    MacLeod wrote: »
    Ummm. OK.
    its a box on a corolla... same engine and everything. Ugliest thing on the road? did u see the pontiac aztec? that car is terrrrrrrrrible. the xb is either very liked for very disliked... but nobody thinks its a bad quality car.
    2013 Toyota Prius
    Mosconi 6to8 v8
  • MacLeod
    edited May 2008
    Ya got me on that one. The Aztec was pretty gnarly looking.
    And I wasnt aware they finally put a decent engine in the xB's. Last year they had a wimpy 1.8 liter or something ridiculous like that. That does help.
  • ROOGER82
    ROOGER82 Posts: 30
    edited June 2008
    hey what's wrong with a 1.3L. I love mine cause its got 200rwhp. Just wish my radio was easier to work with. Damn you mazda and your horrible radio. Though it does have 6x8 and 6x9 stock speakers with a tweeter in the a pillars.
    (Insert clever sig here);)
  • numbronepackfan
    numbronepackfan Posts: 5
    edited June 2008
    I agree with the Altima guy up top. The consumer reports mag I had said that the Inline-4 one was the top rated sedan under $25K and the V6 was the top rated sedan under $30K. This included the new malibu and accord. And on the plus side, drop in speakers on the 6.5s in the door already.
    I could get a good look at a T-Bone by sticking my head up a bull's ****, but I'd rather take the butcher's word for it.
