Help with a pre
mule
mule Posts: 282
edited June 2008 in 2 Channel Audio
I need a little direction, there is so much to choose from I really don't know where to begin.
1st, I would like to have but don't need to have digital inputs for the convenience of hooking the pc up and putting a 400 song playlist on shuffle and doing housework without messing with a cd player.
2nd, I plan on getting a above entry level cd/sacd player for when I really want to sit down and listen to music.
3rd, I really don't see myself getting into vinyl, just too hyper to mess with that stuff :D
Any certain "classic" I should keep my eye open for, carver, nad, dynaco or something of the sort?
Any certain "classic" I should avoid like the plague?
Any certain "bang for the buck" piece I should definately check out, adcom, onkyo, rotel or the sort?
Any overpriced piece I should avoid like the plague?
And lastly, Should I be considering a hybrid tube or tube pre?
Thanks all, I hope your wisdom can save me a little time and money wasted on the wrong piece. :D
Post edited by mule on
  • Early B.
    Early B. Posts: 7,900
    edited May 2008
    Well, I have some questions for you --
    1. Will this pre be for a separate 2-channel system? Do you need HT by-pass?
    2. What is your budget?
    3. Will the pre be used with the Sunfire amp you recently purchased?
    4. Do you want a remote? What about XLR? Tone controls? Two pair of pre-outs?
    "God grooves with tubes."
  • mule
    mule Posts: 282
    edited May 2008
    Early B. wrote: »
    1. yes
    2. I don't have a set budget, if I could get a classic that was simple and worked well for $100 I would be happy, I would have a hard time justifying over $1500, so somewhere in between :D The less I spend here the more I have for a better cd player, but I really don't have the expierience to know how to budget it out.
    3. yes
    4. I don't need a remote but it would be nice. I don't think xlr are important to my wireing situation. I never really thought tone controls improved sound, but again my expierience is limited.
    Just curious, does something like this .. http://philadelphia.craigslist.org/ele/695104484.html sound better than modern technology or is it just the novelty of having something retro, I apologize now if that is a really dumb question:D
    Thanks early, I can allways count on you for logical replies.
  • Face
    Face Posts: 14,340
    edited May 2008
    mule wrote: »
    That ad worries me a little, he spelled McIntosh wrong and his price is very cheap.
    I used to run a vintage McIntosh tuner/pre. They're very colored and warm sounding. If you like the "McIntosh" sound or have a bright rig that needs to be toned down, it's a desirable unit.
  • tcrossma
    tcrossma Posts: 1,301
    edited May 2008
    I've been very happy with my Adcom GFP-750, which sounds like it would fit well with what you're trying to accomplish. It has XLR plus two sets of RCA outputs, HT bypass, and is excellent sounding. Used you should be able to find it for $600-$700.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • dcmeigs
    dcmeigs Posts: 708
    edited May 2008
    How about a tube preamp? A Conrad Johnson PV-5 or PV-10 would be in your price range.
    The world is full of answers, some are right and some are wrong. - Neil Young
  • Bass_Pedal
    Bass_Pedal Posts: 196
    edited May 2008
    Another vote for the Adcom GFP 750. Excellent value at around $700.
    Mains - Vienna Acoustics Mozart Grand
    Subs - Rel T5 x 2
    Amplification - Bryston 3b cubed
    Pre Amp - Marantz Sc11-1
    SACD - Marantz Sa11-1
    Stream - Cambridge Audio CXN v2
    Dac - Marantz Dac-1
    TT - Pro-Ject RPM 9.1 w/ Ortofon 2M Black Cartidge
    Phono Stage - Project Tube box DS
  • TroyD
    TroyD Posts: 13,083
    edited May 2008
    The Adcom 750 is supposed to be a world class preamp.....to me, don't skimp on the preamp. Now, if you can find one, the Melos SHA-1 is a giant killer (and can be had under five bills).
    I do like CJ preamps....I'd try and bag a Premier 10 or 14. The PV series aren't bad either but the earlier versions had great midrange but were a little soft at the frequency extremes and tended to be a little too warm and lush for some tastes.
    Audio Research also has a great following.
    Basically if you are looking at 1500 to spend...man, TONS of great options.
    BDT
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    I'm not a huge fan of 5.1, or 7.1 music except for Dark Side of the Moon, but I do have to ask is the pre going to be used for 2, or multi channel.
    Ben
    Ben
  • mule
    mule Posts: 282
    edited May 2008
    Thanks for the input, I checked out the adcom and that seems like the way to go, very highly regarded.
    What do you think of the nad 118.. http://cls.audiogon.com/cgi-bin/cls.pl?preatran&1215353511 ? That seems like it could give me a little more flexability.
    One more for the adcom experts, is the gtp 750 the same as the gfp but with a tuner? I don't need a tuner but I've come across more of the gtp than the gfp and I can't find the exact details on the gtp, thanks.
  • Bass_Pedal
    edited May 2008
    Here is some basic info on the GTP 750
    http://www.perpetualmarketingonline.com/adcom04.htm
    This unit along with the NAD you mentioned are both Preamps with built in DACs and digital processing or as you might say they are both a Pre/Pro. The GTP 750 is actually a 5.1 Pre/Pro, which I don’t think you were looking for. You mentioned in the OP that digital inputs would be a bonus if you could get them. If that is the case you may want to go with either one of these units since they have built in DACs. The big draw of the NAD is its DSP modes, not sure if you are into that sort of thing but in my mind stereo music and DSP modes are mutually exclusive. As far as quality goes, I have never used either and can’t comment on their performance, however if you mainly plan to use the analogue output of your CD player or have some other external DAC in the mix then I would go with the GFP 750 as it is specifically designed for the shortest most direct signal path in order to provide the truest representation of your source material.
    Subs - Rel T5 x 2
    Dac - Marantz Dac-1
  • zingo
    zingo Posts: 11,258
    edited May 2008
  • del44
    del44 Posts: 686
    edited May 2008
    Another option would be a Musical Fidelity pre.http://cls.audiogon.com/cgi-bin/cls.pl?preatran&1217104835 This one can be had for under $700. I've got the A5 pre, really nice and has a phono pre. Just in case you decide to go vinyl. I'm not sure if the A3cr has the phono, but the A3.2cr does.
  • mule
    mule Posts: 282
    edited May 2008
    Thanks for helping me narrow things down.
    This gfp... http://cgi.ebay.com/Adcom-GFP-750-Balanced-Preamplifier-Preamp-GFP750_W0QQitemZ220239807479QQihZ012QQcategoryZ12050QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    And the above musical fidelity seem like two outstanding options, and they seem like both would make me very happy. I would have to give the a3cr the advantage on styling alone.
    But one last question, if I am using a above average cd/sacd player am I going to have the unit do the da conversion and send analoge to the pre, or am I better off getting something like the lexicon zingo mentioned or the adcom gtp 750 or something similar and connecting with optical or digital coaxial.
    Or more simply, are the da converters in the above mentioned digital pre's better than the da converter in a above average cd/sacd player ?
  • dcmeigs
    dcmeigs Posts: 708
    edited June 2008
    mule wrote: »
    You've asked the correct question. To get the answer you will need to determine which chip is used in each piece of equipment and compare the specs. Look for 24 bit 192kHz chips.
    Here is a Burr Brown data sheet for the PCM-1755
