SDA-2B Xover problem found
fbm211
fbm211 Posts: 1,488
edited May 2008 in Vintage Speakers
I removed the right channel crossover to pack for shipping and noticed that one of those black things with red wire wrapped around it and is strapped to the board is loose.I think it used to be glued down.Anyway there is a lead on both ends that have broken away from the board.I would guess this goes to the stereo driver.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
    F1nut Posts: 51,931
    edited May 2008
    That's one of the inductors. Resolder it to the board and you'll be good to go.
  • fbm211
    fbm211 Posts: 1,488
    edited May 2008
    I dont have a soldering kit and there isnt enough wire to spare to do so.What wire there is seems to have that red coating on it and there isnt enough to reach.
  • dcmeigs
    dcmeigs Posts: 708
    edited May 2008
    Use 600 grit sandpaper on that coating and you will be down to copper. Any hardware store will have a 3.99 soldering iron. Make it happen!
    The world is full of answers, some are right and some are wrong. - Neil Young
    F1nut Posts: 51,931
    edited May 2008
    Go to Radio Shack, buy a soldering gun, solder and some 20 gauge wire. Strip the insulation off a length of wire and make 2 pieces. Then, make a half loop at one end of each piece. Next, scrape or sand the red coating off a short section of each wire coming off the inductor and make a half loop at the end. Join the loop end of the inductor wire with the loop end of the new wire, pinch together and solder the joint. Place the inductor on the board, solder the new leads in the proper holes and use hot glue to secure the inductor to the board. Reassemble and enjoy your speakers.
