swaping tweeters experiment
Braddles
Braddles Posts: 228
edited May 2008 in Vintage Speakers
I have been reading with interest the difference between the current model speakers and how speakers that are made mainly with HT in mind like the RTI range are concidered "too harsh" in the top end for 2 channel listening.
Then i put this together with the Vintage owners saying that the SL2000 tweeters were also a bit harsh compared to later models. So when i got my hands on a pair of monitor 5's for my 2 channel set up i thought i may do a little experiment.
I took the sl2000's from the 5's and swaped them with the sl2500 from the Monitor 12's that are the fronts for my HT.
The 5's are alot smoother with the sl2500's and i like the HT with the sl2000's as i often thought the 12's sounded a bit "flat" when watching movies.
I know the new RDO tweeters have a good following around here and i will go down this road too at some stage but for now i am quite happy with my little swaping experiment.:D
Amp - Jas Audio Bravo 3.2 set
Power Cord - Tunami GPX
CDP - Marantz cd6002 - Audio gd Ref 5 Dac
Speakers - Tekton Lore,Polk Audio RTA11tl completely refreshed.
Post edited by Braddles on
  • McLoki
    McLoki Posts: 5,231
    edited May 2008
    Word of warning - if you think the 2500's are to flat sounding, you may not like the RDO's.
  • Braddles
    Braddles Posts: 228
    edited May 2008
    I know what your saying but they (the 12's) only sounded a little flat with movies not music. I have only recently got a seperate 2 channel set up going. When i get the RDO's they will be for the 2 channel set up.
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited May 2008
    McLoki wrote: »
    +1234
  • hangon
    hangon Posts: 228
    edited May 2008
    I have listened to sl2000's sl2500's, sl3000, up against the RDO's in my 2.3tl's.
    I vote in the RDO's as my Tweeter choice. Not as loud, just as clear and more accurate.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Custom Center made out of a RTA15tl
    Pioneer Elite SC-25 Receiver
    CineNova Grande 5 channel Amp
    Klipsch KA-1000-THX Sub Amp
    (2)Klipsch KW-120-THX Subs
    Basement System
    SRS-SDA 1.2 upgraded Xover
    ADCOM GFA 5500
    ADCOM GFA 5503
    Yahama P7000S Pro Audio Amp
    dbx 120x-ds Sub-harmonic Synthesizer
    2-JBL 4645C Subs
    1-Paradigm SW2200 Sub
    Klipsch Reference in wall's
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    I have not found the RDO's flat, or too laid back at all. I did do the XO upgrade at the same time though.
    Ben
  • zingo
    zingo Posts: 11,258
    edited May 2008
    I would watch out with swapping the SL2500 and the SL2000. They are different tweeters electrically and not made to be in the same circuit.
  • hangon
    hangon Posts: 228
    edited May 2008
    zingo wrote: »
    I forgot to mention, I did not install the sl2000 and the sl2500 into my 2.3tl's. I just swapped the whole speaker (Monitor 10's) I found that the sl2000's were to dull, the sl2500's were better and the sl3000's in my 2.3tl's were to much. The RDO's sound like silk, smooth and calm. My next choice is the sl2500's.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
