HT wall construction
Systems
Found this thru my drywall distributor. Thought you guys building dedicated HT rooms might be interested.
http://www.quietsolution.com
Chuck
Chuck
Testing
Testing
Testing
Testing
Testing
Oooo, I like those! I bet thoughs could even have an effect in a 2-Ch listening room.
I fail to understand why Quietrock would command 6-8 times the cost of regular grade drywall product. You literally could build a double firewall for the cost of a simple quietrock wall.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote: »I fail to understand why Quietrock would command 6-8 times the cost of regular grade drywall product. You literally could build a double firewall for the cost of a simple quietrock wall.
Because its specialty. I'm sure it has a different make up than regular sheetrock, but IMHO I doubt it costs 6X the cost to produce.
