Scientists detail impact of the "Big One" (earthquake) in California
Danny Tse
For those in Southern California, think you're ready?
LOS ANGELES - The "Big One," as earthquake scientists imagine it in a detailed, first-of-its-kind script, unzips California's mighty San Andreas Fault north of the Mexican border. In less than two minutes, Los Angeles and its sprawling suburbs are shaking like a bowl of jelly.
The jolt from the 7.8-magnitude temblor lasts for three minutes 15 times longer than the disastrous 1994 Northridge quake.
Water and sewer pipes crack. Power fails. Part of major highways break. Some high-rise steel frame buildings and older concrete and brick structures collapse.
Hospitals are swamped with 50,000 injured as all of Southern California reels from a blow on par with the Sept. 11 attacks and Hurricane Katrina: $200 billion in damage to the economy, and 1,800 dead.
Only about 700 of those people are victims of building collapses. Many others are lost to the 1,600 fires burning across the region too many for firefighters to tackle at once.
A team of about 300 scientists, governments, first responders and industries worked for more than a year to create a realistic crisis scenario that can be used for preparedness, including a statewide drill planned later this year. Published by the U.S. Geological Survey and California Geological Survey, it is to be released Thursday in Washington, D.C.
Researchers caution that it is not a prediction, but the possibility of a major California quake in the next few decades is very real.
Last month, the USGS reported that the Golden State has a 46 percent chance of a 7.5 or larger quake in the next 30 years, and that such a quake probably would hit Southern California. The Northridge quake, which killed 72 people and caused $25 billion in damage, was much smaller at magnitude 6.7.
"We cannot keep on planning for Northridge," said USGS seismologist Lucy Jones. "The science tells that it's not the worst we're going to face."
USGS geophysicist Kenneth Hudnut said scientists wanted to create a plausible narrative and avoided science fiction like the 2004 TV miniseries "10.5" about an Armageddon quake on the West Coast.
"We didn't want to stretch credibility," said Hudnut. "We didn't want to make it a worst-case scenario, but one that would have major consequences."
The figures are based on the assumption that the state takes no continued action to retrofit flimsy buildings or update emergency plans. The projected loss is far less than the magnitude-7.9 killer that caused more than 40,000 deaths last week in western China, in part because California has stricter building code enforcement and retrofit programs.
The scenario is focused on the San Andreas Fault, the 800-mile boundary where the Pacific and North American plates grind against each other. The fault is the source of some of the largest earthquakes in state history, including the monstrous magnitude-7.8 quake that reduced San Francisco to ashes and killed 3,000 people in 1906.
In imagining the next "Big One," scientists considered the section of the San Andreas loaded with the most stored energy and the most primed to break. Most agree it's the southernmost segment, which has not popped since 1690, when it unleashed an estimated 7.7 jolt.
Scientists chose the parameters of the fictional temblor such as its size and length of rupture and ran computer models to simulate ground movement. Engineers calculated the effects of shaking on freeways, buildings, pipelines and other infrastructure. Risk analysts used the data to estimate casualties and damages.
A real quake would yield different results from the scenario, which excludes possibilities such as fierce Santa Ana winds that could whip fires into infernos.
The scenario: The San Andreas Fault suddenly rumbles to life on Nov. 13, 2008, just after morning rush hour. The quake begins north of the U.S.-Mexican border near the Salton Sea and the fault ruptures for about 200 miles in a northwest direction ending near the high desert town of Palmdale about 40 miles north of downtown Los Angeles.
Scientists chose the scenario because it would create intense shaking in the Los Angeles Basin and neighboring counties a region with nearly 22 million people.
The scenario will be released at a House Subcommittee on Energy and Mineral Resources meeting in Washington.
Here are the major elements:
_10 a.m.: The San Andreas Fault ruptures, sending shock waves racing at 2 miles per second.
_30 seconds later: The agricultural Coachella Valley shakes first. Older buildings crumble. Fires start. Sections of Interstate 10, one of the nation's major east-west corridors, break apart.
_1 minute later: Interstate 15, a key north-south route, is severed in places. Rail lines break; a train derails. Tremors hit burgeoning Riverside and San Bernardino counties east of Los Angeles.
_1 minute, 30 seconds later: Shock waves advance toward the Los Angeles Basin, shaking it violently for 55 seconds.
_2 minutes later: The rupture stops near Palmdale, but waves march north toward coastal Santa Barbara and into the Central Valley city of Bakersfield.
_30 minutes later: Emergency responders begin to fan across the region. A magnitude-7 aftershock hits, but sends its energy south into Mexico. Several more big aftershocks will hit in following days and months.
Major fires following the quake would cause the most damage, said Keith Porter, of the University of Colorado, Boulder, who studied physical damage for the scenario.
The quake would likely spark 1,600 fires that would destroy 200 million square feet of housing and residential properties worth between $40 billion and $100 billion, according to the scenario.
Once the shaking stops, emergency responders would do a "windshield survey" that involves rolling through neighborhoods to tally damage and identify areas of greatest need, said Larry Collins, captain of the Urban Search & Rescue Task Force at the Los Angeles County Fire Department.
Collins said the scale of the disaster means firefighters would not be able to put out every flame.
"We're going to have to think about out-of-the-box solutions," he said.
Post edited by Danny Tse on
I hope not, but I guess it's inevitable. Living here is Seattle, we face the same thing and it sucks to think about.
Learn to swim.
And to think, I would go to work the next day, just like normal.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
It's time to invade Cabo San Lucas, I heard they have WMD.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
I'll never see the attraction to living there. Earthquakes, mudslides, wild fires, congestion, smog, and all that for about $1 billion/ sq. ft. in real estate prices.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
The big one isn't going to happen there. Try ST. Louis.
Google New Madrid. That'll scare you. There was a set
of quakes that went on for months. If it happened now,
St. Louis would be wiped off the face of the earth."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Okay, if that happens, aside from if I have big speakers they might wiggle a little, what am I supposed to watch out for here in Jersey?
If it's bad and we have to house Californians all over the place, I say we give Texas, Oklahoma, N. Dakota, S. Dakota, Massachusetts, Connecticut, Arizona, New Mexico, Virginia, Washington, Utah, Oregon, Kentucky, Indiana, Illinois, Vermont, Colorado, Minnesota, Mississippi, Florida, N. Carolina, S. Carolina, Maryland, Nevada, Pennsylvania, Iowa, Ohio, New Hampshire, Louisiana, Rhode Island, Arkansas, Tennessee, Delaware, Maine, Alaska, Montana, W. Virginia, Wisconsin, Kansas, Hawaii, Michigan, Georgia, Alabama, Greenland, and The Yukon dibs on the first 16 million or so of them. -
Whatever, it's all guess work by these useless scientists that should spend more time doing work that actually matters.If...
Ron loves a film = don't even rent. -
George Grand wrote: »Okay, if that happens, aside from if I have big speakers they might wiggle a little, what am I supposed to watch out for here in Jersey?
We're only gonna keep the cute blonde ones down here."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Some say the end is near.
Some say we'll see armageddon soon.
I certainly hope we will.
I sure could use a vacation from this
**** three ring circus sideshow of
Freaks
Here in this hopeless **** hole we call LA
The only way to fix it is to flush it all away.
Any **** time. Any **** day.
Learn to swim, I'll see you down in Arizona bay.
Fret for your figure and
Fret for your latte and
Fret for your hairpiece and
Fret for your lawsuit and
Fret for your prozac and
Fret for your pilot and
Fret for your contract and
Fret for your car.
It's a
Freaks
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dipshits.
I certainly hope we will cuz
Silly ****, stupid ****...
One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim.
Mom's gonna fix it all soon.
Mom's comin' round to put it back the way it ought to be.
Learn to swim.
**** L Ron Hubbard and
**** all his clones.
**** all those gun-toting
Hip gangster wannabes.
Learn to swim.
**** retro anything.
**** your tattoos.
**** all you junkies and
**** your short memory.
Learn to swim.
**** smiley glad-hands
With hidden agendas.
**** these dysfunctional,
Insecure actresses.
Learn to swim.
Cuz I'm praying for rain
And I'm praying for tidal waves
I wanna see the ground give way.
I wanna watch it all go down.
Mom please flush it all away.
I wanna watch it go right in and down.
I wanna watch it go right in.
Watch you flush it all away.
Time to bring it down again.
Don't just call me pessimist.
Try and read between the lines.
I can't imagine why you wouldn't
Welcome any change, my friend.
I wanna see it all come down.
suck it down.
flush it down.The first rule of Fight Club is you don't talk about Fight Club -
Our worlds population feeds on negativity, why do you think so many millions watch the news? Why do you think useless junk like this is posted. The world would be a much better place if it wasn't for the media.If...
After reading Demi's post, I knew those lyrics would appear."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Cumbre Viejo ...George Grand wrote: »Okay, if that happens, aside from if I have big speakers they might wiggle a little, what am I supposed to watch out for here in Jersey?
