blu ray burners
leroyjr1
leroyjr1 Posts: 8,785
edited May 2008 in Electronics
With blu ray technology being so new , I was wondering if their are any BLU RAY burners and/or software out their. Do they even make blank blu ray discs yet?
your thoughts
Post edited by leroyjr1 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    Blank blu ray disk run up to $50 each!
    The burners are $300.
    I'm going to wait a year. Then I'll jump on blu ray.
    Ben
  • leroyjr1
    edited May 2008
    Did I hear you right, $50 each? Thats not even worth burning a disc for $50 each when you can get the movie for $30 or so. Do you know why they are so high.( Sony must be the only company with blu ray blank discs.) I was thinking they were about $5 each.
  • leroyjr1
    edited May 2008
    Just did some searching and found these
    http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=blu+ray+blank+disc&x=9&y=24
    I think for these prices i see a blu ray burner in my futher. I wonder if the sound (uncompressed, dts hd etc) is the same as well as the picture quality.
  • ben62670
    edited May 2008
    Wow they came down to almost the price of buying the movie!
    I really think you should wait. I am going to. The speed will increase, stability, and don't forget the huge price drop. DVD burners are less than $30 on newegg.
    Ben
    Ben
