LSi25 hook up Question
lumpy
hello all - I have a couple of questions
equipment is as follows
lsi25 mains
lsi9 rears
lsic center
yamaha rxv661 driving the rears and the center
cambridge audio dvd89 for sacd and dvd-a
niles 2125 driving the 25's from the rxv661 pre outs
Q#1. I have the 25's hooked up from a subwoofer splitter cable from the yamaha and then from the yamaha pre outs through the niles amp to the speaker hook ups. I have the jumpers removed in this set up - Is this correct?
Q#2. I have the annalog multichanel hooked up from the cambridge audio payer. do I need to run annalog from the rxv661's pre outs to sepperate amps to the center and surrounds to get the multichane - or should the reciever take care of this?
thanks
lsi25 mains
lsi9 rears
lsic center
thanks
pop
media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
Post edited by lumpy on
1.) No, if I understand that correctly you should be leaving the jumpers in. The only time you would want to remove the jumpers is if you are powering the top posts (the highs / tweeter) with one amplifier and the bottom posts (mids / woofers) with a second amplifier. That would be bi-amping. Or if you were running two sets of wire from one amplifier -- bi-wiring.
2.) Analog multichannel as in you have 6 rca's running to your receiver - one for each channel? Then no, the receiver should take care of that if you are powering the center & surrounds by the receiver. -
Lumpy,
Your speakers are do-able that way. The mid-woofers are cut off at 80HZ, so as long as you have your receiver sub crossover set at 80 HZ or above you will be ok.
You should consider a seperate amp to run the mains, center, and surrounds. From what I read most receivers don't have the power to run 4 ohms loads efficiently. My Yamaha rx-v2500 claims 6 ohm or 8 ohm speakers are compatible, not 4 ohm. It will possibly overheat with 4 ohm speakers, which mine sort of did before I got the Rotel.
I have a Rotel amp running the mains, center, and surrounds. The subs on my LSi25s are connected to the speaker A on the Yamaha receiver. I have the receiver set to "both" to get low frequency to both the LSi25s and my SVS sub, which I have crossed over at 60HZ. This setting works fine for me. I don't want to y split the pre outs to the amp and speakers. You loose around -3db or more from what I've read. Yamaha stays much cooler just running the LSI25 subs this way. Hope this helps. Email me if you have any more questions.
Fatwalnut -
fatwalnut
thanks for the response - I do intend to get sepperate amps for the center and surrounds. The niles audio amp is rated for 200 wpc into 4 ohms for the mains.
How would I be loosing the 3db with the y splitter from the sub out from the rxv661 since the lsi25's have the internal amps for the subs
I would also like to get a good sub for ultra low end, but I wouldn't want it to cancel out anything from the 25's. Any suggestions?pop
