Metal Stands for RM7 Surround
RedRoverSF
RedRoverSF Posts: 1
edited January 2010 in Basic Hookup/Wiring Questions
Hi
I have RM7s for rear surround and I'm looking for a stand. The Polk one requires the wall-mount keyhole adapter (from what I can tell) and that's just an ugly option. I'm looking for some nice black metal, thin profile stands that look good 360 degrees. The screw for the RM7s is right on the bottom, so I figure there's got to be SOMETHING out there that screws directly to the bottom. Sony has a set- but their adapter is curved. I'm going to check to Sony store to see if it's plastic and I can just dremmel the top off, but if somebody has something they like out of the box, give a holler. Thanks!
~Chris
Here is the Sony setup (WSIS10F)
  • Eric W
    Eric W Posts: 556
    edited May 2008
    RedRoverSF wrote: »
    Hi
    ~Chris
    Chris,
    We have the FS RM7 in the works. It may be what you are looking for.
    -Eric
    -Polk Audio
  • xandra
    xandra Posts: 291
    edited May 2008
    Eric -
    Thanks for sharing - NICE lookin Stand!!
    PLEASE More Stands for your speakers (there are palty few suitable for larger Polks - and most are hideous)
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • peemus
    peemus Posts: 1
    edited January 2010
    I'm considering purchasing the FM RM7 Stands but was wondering if anyone could provide some higher resolution photos. The one in this thread is the largest one I've been able to find and you still can't see much detail.
    Also, do they come as a pair or do you have to order them individually?
