What kind of car should I get that would sound good?
danyo1332
I have 2 kicker subs that are 1200 RMS and a 3000watt quantum amp in my cavalier..and inside it sounds great..but outside all it does it rattle!I was going to dynamat it, but i think id rather just get a new car..i was going to get a jeep but i think it would leak because of the plastic windows..then thought about getting a hatchback..but idk what kind?anyone know any that arent TOO expensive..im looking to spen like 5k max..thanks!
Post edited by danyo1332 on
Welcome to Club Polk! You might get better responses over in the car audio portion of the fora.
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
Honda Accord or Nissan Altima.
Both are very well built which means less rattles. The Nissan also has great provisions for a system. Massive kick panels and a massive dash! The Honda isnt quite as good. Although the door locations are good there is a fuse box and hood latch in the drivers kick.polkaudio sound quality competitor since 2005
u know... my dad is the GM of a big nissan store and the altima coup is actualy not built that great...
The lexus is300 is pretty solid, i was looking at my sisters the other day.... its got tweats in the a pillar, 6x9 in the rear and true 6.5 in the doors. + room in the kicks.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
3 words,,,,,,Bavarian Motor Werks.:D Not the Roadster though,,,,.Alpine CDA 9885
Alpine SPX 13REFs in front.
Alpine SPS 400s in rear.
Polk bd 1000 in rear.
Infinity Basslink in trunk.
All in a BMW Z3 Roadie!:eek: -
If you've got the dough, a BMW would be great. More expensive to work on, but motor-wise are bullet-proof.
You'll need to narrow down your options a bit - are you looking for a coupe, sedan, wagon, SUV? Do you have a long commute (ie, need high gas mileage) or do you want a more powerful car for light usage?
Strangely enough, the option that springs to mind is an Accord wagon. The ones from the mid-90s are pretty decent looking and in your price range. There are lots of aftermarket body components for these, and the gas mileage & reliability are both good. Plus, you'll have plenty of space for hauling stereo gear around.
Give a better idea of what your needs are, and we can point you in a better direction.
OTF -
if you like hatches, a toyota matrix is set up pretty well. very good setup that carries would be a cinch2000 Chevy Blazer
db212-2
