5.1 on a 7.1 receiver
Hey guys, this is my first HT setup. I have a pair of RTi10's, a CSiA4, and a pair of RTiA1's for my rears. With a Pioneer Elite 92 receiver.
Just out of curiousity, when your running a 5.1 setup on a 7.1 receiver. Do you put the rear speakers in the surround terminal (second to last terminals), or surround back terminals (last terminals)?
My first instinct is to put them in the second to last terminals (surround), and leave the last terminals (surround back) empty. Would this be correct?
  • janmike
    edited May 2008
    The back speakers are behind you and the surround speakers more in the middle.
    This guide may help.
    HT Roomlayout
    Michael ;)
    NORTH of 60°
  • pietro944
    edited May 2008
    metal83 wrote: »
    That's right,use the surround channels.
    Just go to set-up and input (no) for the
    SB(surround back) channels.
    BTW...you can use the SB channels to Bi-amp your RTI 10's.
    Just be carefull to remove the jumpers
    from the dual binding posts on the speakers and read the manual very carefully.
    It doesn't make any difference whether
    you use the SB outputs for the high or low binding posts,just make sure they're the same for both speakers.
    ...Good Luck,that's a great receiver.
  • metal83
    edited May 2008
    Thank you very much:D. Such a quick response to, very appreciated:).
  • Fongolio
    edited May 2008
    whoops sorry wrong post
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
