Power to the people!
[Deleted User]
[Deleted User] Posts: 7,658
edited June 2008 in 2 Channel Audio
Hello,
Here is an interesting explanation of how amplifier power, speaker sensitivity and transient response all interact. This is part of a response Matt gave to an SRT installation concerning amplifier limiting:
"A normal listening level might be an average of 90db but transients peaks will go at least 20 db above that. In order to preserve those transients the amp will need to produce 100 times more power than is required to maintain the 90db average. Or, in terms of voltage, 10 times the voltage swing.
The SRT is around 90db efficiency at 1 meter from 2.83 volts RMS. That means 78db at a typical listening location 4 meters (~13 ft.) away. So, to produce 90db at the listening location the SRT needs 11.32 volts RMS from the amp. In order to preserve the transients it will need 10 times that or up to 113.2 volts RMS for very short periods of time. High perfromance amps like the Lab Gruppen are actually designed to do this and the speakers are designed to handle it."
I hope you found this of interest, Ken
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    Dear Ken could you translate that to watts for us simple folk:)
    Ben
  • [Deleted User]
    edited May 2008
    Hello,
    Sure, Power equals the Voltage squared divided by the impedance. Take the Voltage and square it, then divide by the impedance, 4 Ohms in this case, and you should have Watts.
    Ken
  • Face
    Face Posts: 14,340
    edited May 2008
    I have the power. :D
  • bikezappa
    bikezappa Posts: 2,463
    edited May 2008
    I love Ohm's Law.
    V=IR
    or
    I=V/R
    W=IV
    Substituting above for I
    W=VV/R=V2/R
  • [Deleted User]
    edited May 2008
    Hello,
    Now you can begin to see why Bob Carver said that it takes 500 Watts to accurately reproduce the sound of a pair of tailor's scissors. In a well known demonstration he recorded a pair of large scissors being snapped shut. Then using a single fairly moderate speaker showed that the peak demand was greater than 500 Watts to reproduce this sound.
    Ken
  • ben62670
    edited May 2008
    Don't let Cathy get a hold of this. We'll never hear the end of it:D
    Ben
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2008
    Those Lab Gruppen amps are impressive!!! 3200w/rms at 23lbs! (just the first model I looked at) Wow, just wow. They look like a Hybrid Class D and H combined, with all of the positive attributes, and none of the negative. Cool.
  • steveinaz
    edited May 2008
    ben62670 wrote: »
    She owes all of you a big "TOLD'JA"...LOL
  • fatchowmein
    fatchowmein Posts: 2,637
    edited May 2008
    So...
    P=(113.2*113.2)/4 = 3203.56?
    So in the example we'll need an amp capable of 3,203W per channel? :eek:
  • Music Joe
    Music Joe Posts: 459
    edited May 2008
    Hello,
    Ken
    I think he stated it was over 2000 watts. Even that doesn't seem right though :confused:
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2008
    THANK YOU Ken!!! Please tell Matt he's GREAT!!!! LOL!
    I TOLD YOU SO!!!!!:p:D
    So just to reiterate...ALL SPEAKERS BENEFIT FROM LOTS OF POWER!!!:D:D:D:D
    I'm going to save this thread & put it in EVERY thread that asks about separate amplification.
    ben62670 wrote: »
    steveinaz wrote: »
  • amulford
    amulford Posts: 5,020
    edited May 2008
    Damn, I thought I was going a little far with over 1 kW. I need MORE...
  • gidrah
    gidrah Posts: 3,049
    edited May 2008
    Hello,
    Ken
    And yet there was still clipping. ;)
    Make it Funky! :)
  • George Grand
    George Grand Posts: 12,258
    edited May 2008
    The story goes that he visited a mad scientist friend of his, and HE was trying to re-create the sound of the scissors snipping, with 12 x 200 watt amps all gang-banged together. There wasn't enough power.
    The more I think about it, the more I feel it was 24 x 200 watt amps, for a total of 4,800 watts, and it wasn't enough. I think the 500 watts statement may be 5,000 watts. I still have that literature around here somewhere, and if I get a chance to dig it out today I will.
  • engtaz
    engtaz Posts: 7,669
    edited May 2008
    Hello,
    Ken
    I was waiting on somebody to bring this up.
    Thanks,
    Roy
    engtaz
    treitz3 Posts: 19,977
    edited May 2008
    From the Carver 1984 Sales Brochure.....
    "Once Bob Carver visited a famous sound researcher who was attempting to recreate the sound of a "snip" of an ordinary pair of scissors. He used no less than 24-200 watt amplifiers for playback., yet when viewed on an oscilloscope it was apparent that the top of that instantaneous transient was being distorted. Believe it or not, he needed more power. "
  • madmax
    madmax Posts: 12,434
    edited May 2008
    Because of this theory I used to have over 13KW for my HT system. A friend still has about 10KW. Power like that gives you a a good snapshot of a live band fully amplified. I'm a 200W tube guy now, thank heavens...
    madmax
    Vinyl, the final frontier...
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2008
    Someone ought to post this over on Audioholics :p:D
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • cfrizz
    edited May 2008
    :eek::D WAAAAAAAAAAAAAAAAAAA!!!!
    Thanks Ron, I just blew water all over my monitor!
    Go ahead & do it. I'll be along shortly to scrape up what's left of your torn apart carcass!!!:eek::eek::eek::eek::D:D:D:D WAAAAAAAAAAAAAAAAAAA!!!!
    (In my best audiophile Audioholics voice) NOBODY NEEDS ANYTHING MORE THAN A RECEIVER! AND IF YOU'RE DELUSIONAL ENOUGH TO THINK YOU NEED MORE POWER THEN BUY A CHEAP PRO AMP!!!:mad:
    Ron Temple wrote: »
  • engtaz
    engtaz Posts: 7,669
    edited May 2008
    Now thats funny.:D
    engtaz
    engtaz
  • Ron Temple
    edited May 2008
    cfrizz wrote: »
    Maybe tomorrow. I've posted a few times over there regarding amps that I'm familiar with and it usually kills the thread dead or is totally ignored :D. Yep, maybe stirring the pot is totally in order.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Face
    Face Posts: 14,340
    edited May 2008
    Ron Temple wrote: »
    Ignorance is bliss.
  • zingo
    zingo Posts: 11,258
    edited May 2008
    Lasareath wrote: »
    Maybe his speakers or the mic that recorded the sound were to blame as well.
    Nope, always more power.:D
    And this coming from a guy who used 15wpc tubes... :o
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2008
    if its all the same I will just keep my measley 20watt Manley. Again, watts are easily manipulated just like some members.
    RT1--Thats my line
    Now bite my hook
  • bikezappa
    edited May 2008
    [QUOTE Again, watts are easily manipulated just like some members.[/QUOTE]
    Thankfully that isn't true about the definition of a Watt.
    However, there are people, for what ever reason, may try to change the meaning/definition of a Watt.
    When you pay the electric bill a Watt is a Watt.
    When you turn on a 60, 100 or 150 watt light bulb a Watt is a Watt.
    A tube Watt is the same as a SS Watt with the same level of distortion and frequency response.
    A foot is a foot weather you use a wooden ruler or a metal ruler.
    A watt is equal to voltage times current. It just plain logic.
  • reeltrouble1
    edited May 2008
    bikezappa wrote: »
    A watt is equal to voltage times current. It just plain logic.[/QUOTE]
    and **** is **** no matter how much paint and pretty you put on it!!!! its **** to believe you need some magic number of watts to enjoy HT or music, eff sissors, how about a guillotine?????????
    i pretty much agree with you but the tube/ss statement is not fact, their are voltage swings with tubes that throw the figures out of whack.
    RT1--you keep biting and I'll keep reelin
  • bikezappa
    edited May 2008
    i pretty much agree with you but the tube/ss statement is not fact, their are voltage swings with tubes that throw the figures out of whack.QUOTE]
    The voltages can vary and change in any manner possible but the definition of a watt still remains the same. That's what makes the formular so beautiful. The formular is more complicated for changes is frequency applied to a capacitive and inductive circuit however.
    And yes people for what ever reason can confuse the peak power and the RMS power to a speaker and to a light bulb. The peak power, watts, can change with time. I think the origin of this thread is to show that there can be very high peak power delivery to speakers.
    However, one watt of power at 60 cycles applied to a speaker will sound the same weather it comes from a SS or tube amplifier or even from a transformer connected to 120 Volt outlet. You just must be very accurate measuring the volts and amps. And that can be tricky if there are fast voltage changes. You would need a scope then not just a volt and amp meter.
    Can you hear the difference between scissors recorded and played back with a 200,000 watt amp and a 20 watt amp? I don't know I never tried it. It would probably depend on the sound level of the playback of the scissors. Do you want to hear scissors playbacked at 120db? Then you may need a 200,000 watt amp. Grin
  • reeltrouble1
    edited May 2008
    bike, i think we are saying the exact same thing.
    RT1
  • [Deleted User]
    edited May 2008
    "gentlemen, there's no fighting in the war room!"
    This is only one area of accurate sound reproduction and was only intended to show how demanding reproducing wide dynamic program material can be. Amplifying power is only one part of a total goal; speaker efficiency and listening distance are part of it, as well. This is a multi-faceted hobby and all parts of it are important and interrelated.
    Maybe for one person having a high efficiency speaker and relatively low power output is the answer. For another a different combination works best, medium efficiency speakers and a moderately powerful amplifier. It's the final level of individual satisfaction that matters.
    I have a friend who is perfectly happy sitting on his sub-woofer cabinet (he maintains he gets the bass through his spinal column) and a pair of Stax electrostatic headphones fed directly by an SACD player. Audio bliss!
    Have fun, Ken
  • steveinaz
    edited May 2008
    Well, this post adresses the proper "scale" of music. People always talk about frequency response, distortion, signal to noise, etc, etc. Rarely do you hear anyone speak of the power needed to accurately reproduce music's scale/dynamic sweep.
    Awhile back, I responded to a thread that "I have never heard drums accurately reproduce on any audio system, at any price"...this topic probably explains why.
    Cool stuff Ken.
