Metal Speaker Stands, Fill with Sand?
mightymouse
I finally got around to have my Target stands assembled. Right now they are unfilled. I am put four thick slabs of blu-tack on the four corners of the top plate, and my LSi9's are resting on top of the blu-tack.
My question is, is the blu-tack sufficient in preventing the transmission of speaker resonance to the metal stands below? Or do I still need to fill the stands with sand? I am kind of lazy, and would prefer not to do too much work...:D
Right now with the speakers set up this way, on some materials, I think I can hear some metallic brightness to the sound. But I am not sure if it is my brain playing tricks on me.:o
Post edited by mightymouse on
Don't use sand, it's very messy.
Use lead shot from your local hardware/home improvement store. -
The choice between sand or lead shot is dependent on how tight the seal is between the pieces of metal. Either way, the sonic improvement is obvious and positive. Blu-Tak or other similar items will help as well but the difference is less pronounced.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
I haven't filled mine with shot yet, but I probably should, just to try it. Let me know what you think of the sound when you get them filled.Tschüss
Zach -
Thanks guys for the helpful replies.
Where can you get lead shot from? Does Home Depot or Lowes carry lead shots? And what size lead shots should I get? -
Steel shot might be safer overall, while still providing the "mass" you are looking for. Finding it locally would be your best bet, as shipping might eat you alive. I haven't checked anywhere myself.Tschüss
Zach -
Lead shot has increased in price.
IIRC local gun store had it for $50 for 25lbs.
Home Depot has 50lbs sand for approx $5. -
I thought the blu-tack was just to keep your speakers from sliding around rather than decoupling them from your stands. I used sand in mine and even with sonic differences aside they're more stable and harder to move, which is always a plus.
I filled my stands with sand, and the imporvement in bass tightness was noticeable. You just need to make sure that the sand is dry before doing it._________________________________________________
When I had stands they were filled with sand, dirt cheap
.....at Home depot
