Epik + buttkicker
SlowcarIX
SlowcarIX Posts: 887
wondering what the result will be :D
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    Should let your system go deeper then ever before. That little buttkicker will go deeper than any sub out there.
  • Face
    Face Posts: 14,340
    edited May 2008
    Very cool.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2008
    I'm running a SVS 20-39CS+ and Buttkicker LFE off of a Samson 1,000w rackmount amp (500w to each). It takes some work to really make the Buttkicker feel like it's complementing the bass from the sub rather than just shaking the hell out of your couch, but IT'S WORTH IT when you get the level right. My floors are carpet on concrete slab and the Buttkicker gives me back that feel of having wooden flooring and feeling the room vibrate.
    I've only bottomed the Buttkicker out once... and that was with a DTS demo CD that has a strong burst below 9Hz. I'm running a subsonic filter on my SVS at around 18Hz and the Buttkicker fills in the rest.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • mhartman29
    mhartman29 Posts: 257
    edited May 2008
    Dude, you are insane!!! You have a conquest and a buttkicker? What does that measure on the richter scale??? :)
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
    Signal Analog II ICs
    Signal Ultra speaker cables
  • JDOGG
    JDOGG Posts: 433
    edited May 2008
    Now you are going to shake your house AND your couch apart.
    Panasonic VIERA 46" 1080p plasma
    Onkyo TX-SR805
    Klipsch RF-7(bi-amped)
    Klipsch RF-25
    Xbox 360 with HD DVD
    Playstation 3
    Cobalt Cable
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2008
    overkill...:D
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Early B.
    Early B. Posts: 7,900
    edited May 2008
    A CD? Or did you mean a DVD? Was it a movie demo? If so, which movie has bass below 9 Hz?
    If it was a CD, what's the title?
    Thanks.
    "God grooves with tubes."
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    This is going to sound rediculous, but the only time I really got my Buttkicker to bottom out was playing Doom for Xbox. Apparently there is lets of LFE around 5-10hz right at the beginning of the game.
    Early, of the top of my head Black Hawk Down has some 6-8hz info at the Irene scene, and Hitchhiker's guide to the galaxy does to...as well as I think Final Destination 2 (log scene) and WotW (lightning scene) . There are more but I can't remember them off the top of my head, just search avs for the waterfall thread.
  • SlowcarIX
    edited May 2008
    i have carpet on cement slab too.
    1st impressions....the feel is very unnatural - conquest alone perform better. How much did you turn the volume on the buttkicker up to, just enough to feel it?
    also i got the wireless transmitters, they were worthless - made the buttkicker go off even when there is no signal input. So now i just run the lineout from the conquest direct to the back of the butt kicker amp.
    my 7.(1x4) HT setup
    Buttkicker
  • kuntasensei
    edited May 2008
    Early B. wrote: »
    Thanks.
    I meant a CD. You can burn DTS-encoded .wav files to CD, then they play back just like a redbook audio CD would, but in DTS. The disc in question was a DTS demo disc, and the track in particular was one of a jungle with a dinosaur stomping through it. Absolutely brutal bass. I'll see if I can dig up the title when I get home.
    Equipment list:
    Emotiva XPA-3 amp
  • kuntasensei
    edited May 2008
    SlowcarIX wrote: »
    Well, I'm not running the Buttkicker's amp; I'm running mine off one channel of my Samson 1,000w rackmount amp... plus, my level is affected by my Audyssey MultEQ XT calibration, so I can't give you an actual level.
    To set my Buttkicker level, I basically just bounced between a few DVDs that I'm used to hearing - Saving Private Ryan DTS, The Haunting DTS (which softly bottomed the Buttkicker once, but when it happened I registered a 113dB burst from my SVS - way louder than I would ever listen to anything, but I was showing it off to a friend), and U-571 DTS (the infamous depth charge scene). I backed the Buttkicker off to where it is only really noticeable with explosions, etc. - not apparent the whole time you're watching a movie. It isn't supposed to shake your couch like a theme park ride so much as just add a slight tactile feel to really deep bass, as if you were on a wooden floor. In my room, no one notices it until something really loud and deep happens.
    It takes some time to find a good unobtrusive level that blends well with your sub, but give it time and I think you'll be happy. Did you also get the isolation feet to decouple your couch from the floor?
    Equipment list:
    Emotiva XPA-3 amp
  • Meeks32
    Meeks32 Posts: 330
    edited May 2008
    Jurassic lunch?
  • SlowcarIX
    edited May 2008
    these are my settings on the BK amp - low cutoff = off, high frequency cutoff = on@40Hz. all the feets are on isolators xcept the one thats sitting on the BK mounting plate.
    with the vibration of air/room/couch caused by the sub, it feels good/natural...but once i crank up the dial on the BK amp till barely feel it, it seems to overwlm the sensation caused by the sub...the good feel goes down the drain...:confused:
    might be a case of 2 positive makes a negative...
    my 7.(1x4) HT setup
    Buttkicker
  • shadowofnight
    shadowofnight Posts: 2,735
    edited May 2008
    I love the look of those flared 6" ports :) I have a couple of the Precision Port 6" flared to use in a new build soon as well.
    That cat looks like it wanted to crawl up in one of those 6" ports , but using its better judgement didnt ;)
    One thing does surprise me though....I dont know if it is the angle of the picture or not, but it looks like a bare MDF wall straight behind the port ?
    Usually that area behind the port is shot with black paint a few inches in diameter larger then the port so you dont see the bare MDF.
    I have even seen them paint damping material lining walls behind a port so you dont see the color of that material either.
    Hell 6" ports are big enough to stick a small digital camera INSIDE for pics without even disassembling anything :D
    Very nice sub......
    The first rule of Fight Club is you don't talk about Fight Club
  • Face
    Face Posts: 14,340
    edited May 2008
    SlowcarIX wrote: »
    Can you reverse the phase on the BK?
  • kuntasensei
    edited May 2008
    Face wrote: »
    You can reverse phase by swapping the positive and negative leads. Not sure what good it would do you with a transducer though.
    And yes, Meeks... I believe Jurassic Lunch is the name of the track on that DTS demo disc.
    Slow, try turning the high filter up to around 70 then backing off the level a bit. You should be able to find a sweet spot where the Buttkicker just mildly reinforces what you're getting from your sub.
    Equipment list:
    Emotiva XPA-3 amp
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    SlowcarIX wrote: »
    I setup mine just like my sub before I got a SPL meter. Find a scene in a movie that you know with lots of <40hz bass. Turn the BK up to a point where it is really noticeable. Very slowly turn it down until you can't really feel the effect, then up it slightly from there.
    I had mine for 3-4 months and always felt it was gimmicky until I properly set it up. I personally used WotW Lightning Strike scene to set mine up. It should seamlessly blend with your sub, so you really can't tell where the bass is coming from. Oh yeah, and it helps to turn the unit on/off while setting up, do it while adjusting the level down to get a reference of what the sub is like alone.
  • SlowcarIX
    edited May 2008
    i got a total of 24 feet of sub cable(RCA) - 12 between the avp to the conquest and 12 between the conquest to the bk amp...will that be an issue?
    my 7.(1x4) HT setup
    Buttkicker
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    Are you worried about noise or delay cause by the long cable? You could always get a y-adapter off your avp.
  • SlowcarIX
    edited May 2008
    any idea where i can get a high quality 1x male rca to 2x female rca y splitter?
    my 7.(1x4) HT setup
    Buttkicker
  • Face
    Face Posts: 14,340
    edited May 2008
    Signal Cable or BJC.
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    I personally don't like going the cable route, I just use the simplest I can find which is usually little $. I use this y from Radio shack to split the signal between my BKA and SVS, I bought it because it was cheap, gold plated, small, and grips quite well. I have seen the ACI Y recommended alot as well as the PE which looks quite similar.
  • SlowcarIX
    edited May 2008
    i got the Dayton RCAAD-MFF RCA Male To Dual Rt Angle RCA Female from PE, its see if it helps. thanks
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited May 2008
    i guess it was the long cable distance (24') that might have caused a lag between what my butt felt and the pressure waves generated by the sub. i would think that electrons travel much faster than sound waves.......:confused:
    anyways its great now - the unatural feel is gone :D
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited May 2008
    btw thanks Gaara!
    my 7.(1x4) HT setup
    Buttkicker
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    SlowcarIX wrote: »
    btw thanks Gaara!
    Glad it fixed the issue.
