RTi70/CSi40 users - what are your crossover settings?
dbaldus
dbaldus Posts: 730
edited May 2008 in Speakers
Title says it all. I'm trying to get a feel for what people are using for crossovers when running a pair of RTi70's with or without a CSi40 center. I personally have had a hard time telling a difference between having it set at 60, 80, or even 100Hz, so I was curious what all of you have found to be the best setting?
My current system is listed in my signature...
Thanks!
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
Post edited by dbaldus on
  • john22614
    john22614 Posts: 214
    edited May 2008
    I had a CSi40 before I got my LSIc and had it set a 80 just 'cause that's what was recommended. It sounded good to me. When I tried it a 60, I couldn't tell the difference either.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • dbaldus
    dbaldus Posts: 730
    edited May 2008
    john22614 wrote: »
    Where did you get this recommendation, out of curiosity?
    2-channel
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2008
    I've found that a good rule of thumb is to set crossovers so that you get about a half-octave above the -3dB point for the transition from speaker to sub to occur (based on the common 12dB/24dB per octave crossover slope used in AVRs). On my Onkyo 705, I'm running my RTi70s at 60Hz (40Hz -3dB point x 1.5 = 60Hz) and my CSi40 at 70Hz (50Hz -3dB point x 1.5 = 75Hz).
    You can see from the math that 80Hz will give you a little more transition with the CSi40, but I found that I got better response from deep voices using 70Hz. If you have the option, it's worth trying. Otherwise, use 80Hz.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Fongolio
    Fongolio Posts: 3,516
    edited May 2008
    Mine's set at 80 although I'd prefer 60 but it's not an option on my Pioneer Elite VSX-52tx. Goes from 50 which is too low to 80 which is the THX recommended frequency but a little too high. I think the RTi-70's and the CSi40 can can handle a little lower and still sound great. My RTiA7's are quite happy at 50 but since the 70's are doing surround duty I balance the whole thing for best overall sound. Also the transition from the subs to the fronts and surrounds on really bassy stuff is better at 80. I really wish 60 was an option.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • john22614
    edited May 2008
    80 is usually the standard recommended crossover by AVR manufacturers and speaker companies too......as a general rule, Polk customer service would suggest 80.....I suspect that's what the majority of people do... but, it's not etched in stone. Having said that, one of the great features of you center is the large drivers that can handle 60 nicely. I think either one is fine.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Comcast DVR
    Itunes Air Express
