Totem Rainmaker and Totem Arro
bopicasso
bopicasso Posts: 878
edited May 2008 in Speakers
Im in the market for a upgrade. I currently am running rti8s. Does anyone have and experience with Totem acoustics? I have found some fair used prices on the rainmaker and arro.. Would these speakers be an upgrade to my rti8??
Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
Post edited by bopicasso on
  • SolidSqual
    SolidSqual Posts: 5,218
    edited May 2008
    They are upgrades in sound for sure, but understand that the RTis are made for HT and to go real loud. The Totems are made for Music and to go depp but not at high volumes. Also, the RTis are made to rock our whereas the Totems you indicated are more jazz and blues speakers. They are not Big Hair Band or Tool or Coolio speakers. That being said, I've heard both Totems and owned the Rainmakers. They will be a major improvement in music.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited May 2008
    I owned the Arros for about a six or seven months. Absolutely top rate in a small room and had 'em mated with a Monarchy SM-70 Pro. Their imaging ability is uncanny. Extremely fun speakers.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2008
    Totem makes a wonderful loudspeaker across the board.
  • bopicasso
    edited May 2008
    Well the reason I want to upgrade is because Im not happy with the way my RTI8s play music. Acoustic music sounds fine, but rock music, doesnt sound that good. They are great for HT though, I would like something that is a all around good music speaker while still good at HT..
  • haimoc
    haimoc Posts: 1,031
    edited May 2008
    bopicasso wrote: »
    In my experience, Polk LSi are excelent and best for both music and HT.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited May 2008
    I agree, polk LSis are pretty awesome for movies and music. . . if you have the right equipment to drive it.
    If you don't have a beefy receiver or separates, I would try to find some good speakers in the 90+db range and 8 ohms. Paradigm Studios seem similar in price and build to Lsis but easier to drive.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • bopicasso
    edited May 2008
    I have a onkyo 805. I dont think that would be good for polk lsi speakers.. I guess it could drive them till I can afford a upgrade. I was considering polk lsi9s..
  • markmarc
    markmarc Posts: 2,309
    edited May 2008
    The Onkyo will do ok with the Totems, but since you have a preference for rock over acoustic, and matching with the Onkyo, I'd suggest the Paradigm Studio 40's. Or, go vintage with a pair of Polk 10's.
    Former Staff Member TONEAudio
    2 Ch. System
  • zombie boy 2000
    edited May 2008
    The Arros are very power hungry as well, though I did power them quite nicely with 35 class A watts. Being used in a small room also helps.
  • mule
    mule Posts: 282
    edited May 2008
    I listened to the totem rainmakers and thought they sounded awsome, but then the salesman switched on a set of Monitor Audio rs6, they sounded head and shoulders better and by the time you buy quality stands for the totem's you will be about the same price point.
    The Totems are beautiful and great sounding speakers but at that price point I like the Monitor Audio speakers better, but of course thats a matter of opinion.
  • dorokusai
    edited May 2008
    The Onkyo would be fine and you can re-assign the rear amp channels to bi-amp if I recall correctly.
  • bopicasso
    edited May 2008
    Thankyou everyone for your recommendations!!!!
  • SolidSqual
    edited May 2008
    Zero, touches on a good point here. Totem products are damn picky when it comes to what's feeding them. I've heard several thousand dollars of gear on a pair of Hawks that did not sound as good as a $600 preamp and a $700 amp.
    Zero wrote: »
    Bopicasso,
    Most of the folks in these parts know that I dig Totem products.
    That said; the only Totem I know of that is perfectly adept for dual purpose listening is the Forest. The Sttaf is also a wonderful multi-talented performer. Unfortunately, neither product will shine on an Onkyo receiver.
    I would instead direct you towards other loudspeakers from the likes of AV123 or Ascend Acoustics. Even companies like the aforementioned Paradigm and Monitor Audio can deliver the goods without requiring a big investment in time and component upgrades.
    Good luck.
  • bopicasso
    edited May 2008
    dorokusai,
    I forgot all about bi-amping, so I broke out my manual to the 805 and decided to bi-amp the rti8s. Alot more bass! Wow I was impressed! Thanks!
  • dorokusai
    edited May 2008
    Cool. It's a cool feature and you didn't spend a dime.
  • markmarc
    edited May 2008
    A fine effort Doro, not many receivers offer the option you suggested. Hopefully others with the Onkyo 805 will find and use your suggestion.
    2 Ch. System
  • bopicasso
    edited May 2008
    It definately works, my better half even noticed.. If she noticed, it made a difference!!
  • LuSh
    LuSh Posts: 887
    edited May 2008
    The Totems can sound nice, but you have to ask yourself was it worth the effort. I would highly recommend anybody who is thinking of using Totems to buy from an authorized dealer who has been dealing with Totem for many years. I had mine for a year or two and couldn't stand them, I just couldn't get a combination that would work.
  • dorokusai
    edited May 2008
    You mean the Meitner/Moray combination failed you? better call the New York Times!
  • LuSh
    LuSh Posts: 887
    edited May 2008
    I don't know what bug is up your **** doro...
    Zero seems quick to reply these days too.
