RT1000p Subwoofer Amp Hum
rmf5
Hello All:
I recently purchase a pair of RT1000P tower speakers and have notice that one of the two has a hum when the subwoofer amp is on regardless of power plug and whether the stereo is on. I don't think there is a grounding problem, but would like to rule that out before considering a repair or replacement of the amp. Any suggestions? Also excuse the ignorance, but do the subwoofers operate without the amplifer and is there a way to activate them without having the amplifiers on?
Thanks.
Thanks.
Post edited by rmf5 on
Are you running a separate RCA cable to the amp from your Sub or line-level pre-out on your receiver? If so, try disconnecting it and see if you still get the hum.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
