Vista Service Pac 1
ben62670
ben62670 Posts: 15,969
edited May 2008 in The Clubhouse
Anyone brave the new service PAC for Vista? I'm going to go for it. I normally recommend waiting on new service pacs, but being in IT I have to deal with this stuff when it comes out.
Ben
Post edited by ben62670 on
  • ben62670
    edited May 2008
    Installation warning...
    This installation may take an hour or more:eek:
    Ben
  • ben62670
    edited May 2008
    about 25 minutes on a quad core:p
    we'll see how she runs:eek:
    Ben
  • danger boy
    danger boy Posts: 15,722
    edited May 2008
    PolkFest 2012, who's going>?
  • ben62670
    edited May 2008
    Thanks DB. How embarrassing I even posted in that thread:o
    Ben
  • Roy Munson
    Roy Munson Posts: 886
    edited May 2008
    I installed SP1 last month and all went smooth.
    Took about 30 minutes on a 2.8 dual core with 3 gigs of mem..no problems.
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
  • haimoc
    haimoc Posts: 1,031
    edited May 2008
    Roy Munson wrote: »
    Same here... about 30 mins with no problem on a dual-core laptop.
  • Kris Siegel
    Kris Siegel Posts: 309
    edited May 2008
    Installed on 3 of my machines. 2 C2D and 1 4600+ machine (64-bit Vista installed). On the laptops (c2d) it took about 30-40 minutes but my desktop (4600+, 64-bit) only took about 20 minutes. I also have 4 GB of ram in it as well as a WD Raptor (10,000 rpm WD HD) so I'm sure that may have helped :D
  • Systems
    Systems Posts: 14,873
    edited May 2008
    I couldn't get windows update to see it, so I did manual download and install.....everything went fine.
    Testing
    Testing
    Testing
  • Kris Siegel
    edited May 2008
    Microsoft was blocking Windows Update from certain people who had drivers known to be incompatable with SP1. Not sure if that's still the case or not but if it is you could be in for a rough ride.
  • Systems
    edited May 2008
    I do have on yellow mark in the device manager, can't for the life of me figure out what its for though, it just shows unknown device......Everything else is working fine except for the sound drivers, the sound is just terrible. Its an old SB Live card and theres no drivers from Creative for it, am just using Vista's.
    I'm not using Vista very much actually, I have it dual booted with xp so am mainly in xp most of the time.....
    Testing
    Testing
    Testing
  • ben62670
    edited May 2008
    I usually download the IT service pack. The full versions are less likely to fail on installation.
    Ben
    Ben
