Wich Subwoofer ??
I have a pair of new rtia9's and a rtic4 center.pushing each front wit a outlaw m 200 ,200 watts . I need more bass .What sub is good for music not movies. Budget around $600.00 thanks
Post edited by Neale13 on
Just some additional general questions to make sure the recommendations are spot on and you end up with what you want for the $$ spent.
- Any other constraints besides budget? (size (subwoofer physical dimentions), volume (how loud), etc.)
- What kind of music do you listen to that your RTia's are not taking care of the bass for you?
- What is lacking in the bass you have now? (not deep enough, not enough presense, not enough impact, out of balance with rest of speaker, etc.)
- Any possible room issues going on? (i.e. just a bad room for bass???)
Michael
No size issues. I used to have a pair of cerwin vegas with 12 inch subs in each and the bass hit very hard,tight and would make you think you were at the concert.I listen to rock,modern rock and alternative rock.thanks
