LS series feet
NotaSuv
Does anyone know how the the metal feet were attached....screwed or ????? ...mine just spin and right now dont want to force anything..wanting to remove and replace with carpet spikes...thanks
Post edited by NotaSuv on
Hmm, the ones on my LS90s are threaded for level adjustment. Did you try to unscrew one all the way?
I asked Polk CS about spikes a while back and they indicated that spikes from another series (LSi, IIRC) would work. I never bought them though.
I have not seen the bottom of mine for while, but I would guess that the feet screw into threaded inserts in the cabinets. The threads are probably a standard, like 1/4" 20 or something, which means you might also be able to find some suitable spikes elsewhere too.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
mine just spin and spin
even when i put a vice grip on em and pul they just spin...
