XP vs. Vista DVD copying.. er, I mean, backing up
burdette
burdette Posts: 1,194
edited May 2008 in The Clubhouse
We have an Win XP PC. We have a Vista laptop.
Last night I tried to backup two DVDs using DVD Shrink and Decryptor, and got errors almost immediately on the laptop. They both went fine on the XP.
It seems that either Vista, or newer versions of Windows Media Player, have some sort of built in copy protection that kicks in.
Is it possible to make settings changes in Vista or on the Vista machine so that I can copy the same disks on that machine as I can on the XP machine?
Post edited by burdette on
  • Sami
    Sami Posts: 4,634
    edited May 2008
    I've had no problems in Vista with either program, works the same as it worked in XP.
  • McLoki
    McLoki Posts: 5,231
    edited May 2008
    I use a freeware app called deep burner to copy the .iso files. (I use DVD shrink to create the .iso and then burn the .iso with deep burner)
    seems to work ok - give it a shot.
    heiney9 Posts: 25,513
    edited May 2008
    I wouldn't use the current version of VISTA if Microsoft paid me a daily stipend. I'm perfectly fine with my XP-Pro. Sorry couldn't add anything of value, but VISTA seems to have a lot of different issues as you've found out.
  • Deadof_knight
    Deadof_knight Posts: 980
    edited May 2008
    The way I figured it out . after 3 more years Vista will be ready to use.... as was xp and previous versions ...............................
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Roy Munson
    Roy Munson Posts: 886
    edited May 2008
    I use AnyDVD with either Nero Recode or CloneDVD.
    Vista rocks!
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
  • scootchu
    scootchu Posts: 100
    edited May 2008
    Works Great on my 166Mhz with MMX machine running Millenium Edition!!!
    Seriously I have a Vista machine and Shrink works, albeit slowly, without errors. If you are getting the "redundancy" error I would try DVD Fab HD.
    That seems to work on the newer discs released lately that Shrink has problems with.
    Rip-it-4-me was a cool one click solution, but I believe "the man" caught up with it and it's still out there, but hiding.
  • Roy Munson
    edited May 2008
    Ripit4me was great freeware but is no longer supported!
    2 Channel:
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2008
    I have no problems in Vista...
