Mixing RTi with RTi A Series
Right now I've got a 5.1 with RTi12's, CSi5, and FXi3's. I am finally building a dedicated theater room and want to go to 7.1. I assume that the RTi A series is a good match (since I can no longer find the old series) but had 2 quick questions:
1. Is it worth it to go with FXi A6's or will FXi A4's be ok?
2. If I go with FXi A6's should I then use them as side or rear? Not sure if either position puts out more sound than the other.
Thanks.
Thanks.
A lack of planning on your part does not constitute an emergency on my part...
Post edited by RVJII on
bump, because it's a good question that I would like to know as well!
TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3 -
What's your room size and what are you currently using to power your 5.1 setup? Depending on the answers to those questions, I would most likely recommend skipping the 7.1 setup and going with better amplification of your current speakers.My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
I've seen plenty rti old series bookself speakers on ebay and craigslist is that a option
http://cgi.ebay.com/POLK-AUDIO-RTi4-ONE-PAIR-SPEAKERS-CHERRY_W0QQitemZ310055987236QQihZ021QQcategoryZ3275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/POLK-RTi6-BOOKSHELF-SPEAKERS_W0QQitemZ150254236048QQihZ005QQcategoryZ14991QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/POLK-AUDIO-RTi6-ONE-PAIR-SPEAKERS-CHERRY_W0QQitemZ310055986422QQihZ021QQcategoryZ3275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/POLK-AUDIO-RTi4-ONE-PAIR-SHELF-SPEAKERS-BLACK_W0QQitemZ170225349075QQihZ007QQcategoryZ3275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Polk-Audio-RTi6-Bookshelf-Speakers_W0QQitemZ150255476466QQihZ005QQcategoryZ14991QQssPageNameZWDVWQQrdZ1QQcmdZViewItem -
No complaints from me on my FXi A4's. For me I choose the side postion and the RTi 6's for the rears.
The placement depends on your room. I choose the side, and set them to Dipole. After you get them see what placement you prefer.Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
go for a pair rti3s if you can find them for your rears, use the fxi3s as your side surrounds.Shoot the jumper.....................BALLIN.............!!!!!
What about using FXiA speakers for rears instead of A1's or A3's. Would FXiA's be better? I currently have the A1's on my side walls, but almost touching my back wall. I'm looking to upgrade to either the A3's or the FXiA's. Oh any i am only running 5.1 because of my room setup.
