KRK K-ROK monitors
I just picked up a pair of passive KRK K-ROK monitors on a whim. I don't have any experience with pro near-field monitors, but I thought it would be a fun demo and I might just like them. I have not had a chance to demo them yet, but tonight I will hook them up and give them a good run for their money and report back with a full review. As far as I can tell, they retailed for close to $1K new, so I'm excited to see what they sound like. KRK is a respected monitor brand, that I have heard good things about. I am not expecting the world since they are monitors and are made to be "analytical and critical"; but I figure if a sound engineer can listen to a track all day on them, why couldn't I?
Visual and tech review:
The KRK K-ROK is a stout 14" tall with tapered sides from a 12" base. This taper is supposed to reduce standing waves. A 1" silk dome tweeter and 7" latex-coated paper woofer with rubber surround split the signal at 2.5kHz to form the 2-way design. The speakers are constructed of 1" MDF and are very solid with rounded corner and two ports that nestle between the two drivers. They are rated at 8 ohms with an efficiency of 92 dB 1w/1m, and 100wpc. They weigh in at about 22lbs a piece and can take just about any abuse you can throw at them with their stout, solid build and "industrial" gray coating. The back of the cab is finished off with a set of 5-way binding posts to accommodate a number of termination choices.
Listening review:
Well, it turns out that both the tweeters are not working on these babies. I pulled them to double check that it is the tweets and not x-over or something, and both tweeters are DEAD. Bad times. I e-mailed KRK to see of they have replacements, but I'm not holding my breath. The only bright side to the story is that I got the speakers at the local thrift store for $15. They looked to be in great condition and the mids moved free so I thought I'd give them a try. It's weird that both tweeters are completely dead, but maybe I can find replacements; who knows.
Test system:
Custom built integrated tube amp
PC as source via S/PDIF uncompressed
AMC 8 DAC
Z Cables and ICs
Listening review:
Test system:
AMC 8 DAC
Z Cables and ICs
Post edited by zingo on
KRK e-mailed me back and the replacement tweeters are $35 each. Not bad, but I don't know if I want to spend it for a demo that I may not keep...
I also picked up a pair of these great KRK K-Rok speaker monitors at my local ebay connection in Phoenix, so I did't have to pay shipping. It is nice when they post heavy items like speakers, I have a bit of an unfair advantage when it comes to bidding.
It works for me.
Anyway, I am new to the hardware end of things in the audio music world. I have been bitten by the vintage bug thanks to the new Goodwill store that opened up a half mile from my house and I like tinkering. Unfortunately, I have a lot to learn when it comes to testing and fixing audio equipment. What did you do to test the tweeters to verify that they were not working? How do you do that? Do you have any advise on how to go about learning the basics in audio testing and repair as a hobby?
Thanks,
Chris -
Its working is not good !!! i have also bought but after a short period its working is too slow .chanab44
