PA1100.5 to SR104DVC
do you think this will give the sub enough power?
Post edited by dimat327 on
  • Eric W
    Eric W Posts: 556
    edited May 2008
    The answer to almost all audio questions is "it depends." Depends on your vehicle, the application, the material to go through the system and ultimately how loud you expect the subwoofer to play. Otherwise that combo should satisfy most listeners. It won't break any world records but it'll be alot better then any factory system.
    -Eric
    -Polk Audio
