dvd widescreen and 16:9
tony27
tony27 Posts: 49
edited December 2002 in Music & Movies
Hi. will my widescreen dvd's now fit the tv screen if I buy a 16:9 aspect ratio tv?
Post edited by tony27 on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Yup.
    SVS
  • caseymou
    caseymou Posts: 327
    Correct me if I am wrong but you must use the component video outputs on the dvd to get a true widescreen picture.
  • HBombToo
    HBombToo Posts: 5,256
    casey,
    theres a bunch I don't understand about vidio and I'm just sharing what I have. My Cal Audio CL-20 is not progressive scan nor has component vidio out but has the option for both 16:9 and 4:3 so I think its moreso a function of the dvd player and not the connection.
    I don't think, "but don't know for sure", that you can get a progressive image with s vidio... you need component connections and hdtv capable.
    HBomb
    ***WAREMTAE***
  • Ron-P
    Ron-P Posts: 8,519
    No. Not all DVDs will. A 16:9 Widescreen TV has a fixed Aspect Ratio (AR) of 1.66:1. Movies though, are filmed in various AR's. Most all are film in 2 AR's, 1.85:1 and 2.35:1. With the 1.85:1 you will not have black bars due to your TV's overscan. With movies that are 2.35:1 you will have small black bars. Most of you DVDs will have the specs on the back as to which AR they are shot in.
    Well, sort-of. You need component cables wired up to a progressive scan player, wired to an HD-ready TV to get the true benefit of anamorphic DVDs (this is the only way). A standard DVD player with standard hook-up will still gain you a widescreen picture, just not as nice a looking picture.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • HBombToo
    Ya! What Ron said. ;)
    HBomb
    ***WAREMTAE***
  • Steve@3dai
    Steve@3dai Posts: 983
    Mmmmm.... widescreen.
    IIRC, 2.35:1 is true "movie theater" ratio, correct? I can't get those two straight.
    LSi 9/C/FX
    Arcam AVR-200
  • Ron-P
    Ron-P Posts: 8,519
    There is no "true" movie theater ratio, it's whatever the director decides to use for his moive. Obviously, the more epic type movies use the 2.35:1 where your family and comedy types go with a 1.85:1.
    Peace Out~:D
    If...
  • Dr. Spec
    Regardless, if you are into HT, I think a widescreen HD monitor and a progressive scan DVD player with component video output is non-negotiable.
    DVD format continues to improve - even if it is not true HD. Many recent transfers are very impressive.
    Doc
    SVS
