WTB: Volex 17604 Power Cords
tryrrthg
tryrrthg Posts: 1,896
edited May 2008 in Wanted (WTB) Classifieds
I'm looking for 4 Volex 17604 power cords. anyone have any laying around that they would part with?
Thanks!
Post edited by tryrrthg on
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    If you don't find any of these then check Head-Fi's FS forum. They seem to pop up once every few weeks or so, the old style not the cheaper new ones.
  • tryrrthg
    edited May 2008
    Thanks for the info.
    Bump...
  • joeparaski
    joeparaski Posts: 1,865
    edited May 2008
    Why don't you just order some, they're not expensive.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • tryrrthg
    edited May 2008
    joeparaski wrote: »
    Joe
    That USED to be the case, but now most places want nearly $20 per cable after shipping. I don't see that as worth the money like they used to be at $4-5 a cable. For a little more than the current cost of the volex I could get a PS audio power/super punch cable.
    Edit: Carlton Bates has them for just over $8, but they don't have them in stock and they have no idea when they're getting any in stock.
    Edit again. I did find them at Arrow Electronics for around $9, which isn't too bad. I'll probably order them up there.
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    I assume you know the difference between the old and new style of 17604? If not I know the older ones were made in Mexico not China like the new ones, the new ones don't have the brass plated connectors like the old ones, and I think the wire is a different variant of Belden between the two. I have both and definitely prefer the look and feel of the old ones, albeit I can't hear a difference between them, just differences in perception.
    The older ones are said to be much better, there are threads on Head-Fi and Audio Asylum about them.
  • joeparaski
    edited May 2008
    Hmmmm...I didn't know about the "Chinese" connection. I bought a case of 30 from Carlton Bates some time ago to redo all my gear with, they are NOT brass plated, so I assume they're the "better" ones? I still have 10 left, I wonder if I keep them long enough if the price will go up like 1000%:rolleyes::rolleyes:
    Joe
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    joeparaski wrote: »
    Joe
    The older style are universally thought of as superior, the connectors are folded brass and fit tighter then the newer style ones.
