KAB EV-1 record cleaner
apc
Have any of you ever tried or do you own one?
Husband, Father, Son, Brother, Friend.
I've had one for over a year now. If you can live without the conveniences of the pricier ones, like a motorized platter, auto scrubbing and fluid application, it's great. It's a lot quieter then a VPI, IMO, 'cause you can locate the vacuum farther away from you. The only downside that I've noted is the vacuum tube on it being exposed. Sometimes I forget to wipe it off before I vacuum a record, and it leaves a trail of dust on the surface of the record.Wristwatch--->Crisco
