Im thinking of running my laptop...
VR3
VR3 Posts: 29,627
edited May 2008 in Video Games
Through my 2 Ch/TV setup --
Basically run on the monitor out to the TV - run 1/8" to RCA to the TV --- and of course TV outputs to the Candela...
Ive done this before when needed, and the picture is always a little off as far as centering. Is there a way to fix this.
Are there any other variables I should know?
Post edited by VR3 on
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2008
    Are you using the HDMI input on your TV? For the best picture quality, you should get a DVI to HDMI cable, and connect your laptop this way.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • fatchowmein
    fatchowmein Posts: 2,637
    edited May 2008
    Try changing the screen resolution. Usually, going from laptop to TV requires something like 640 x 480 or 800 x 600 for standard screens (you'll have to experiment with wide-screens). Trying searching Google or the manual to see if there's a resolution recommendation for connecting to your TV.
    Good luck!
