Non-Common Ground Amp connection
hangon
hangon Posts: 228
edited May 2008 in Vintage Speakers
I have the CineNova Grande Amp, I called the factory (Earthquake) today about the common ground interconnection cable issues (connection of my SRS-SDA 2.3tl). This Amp is a Mono Block design and it will not work with the factory interconnect cable for common grounds. I have searched for the "isolated interconnect cable", or how to build one myself and slim results. I called Ken At Polk Audio today and he suggested posting a new thread asking for help.
HT Theater
SRS-SDA 2.3tl RDO's
Custom Center made out of a RTA15tl
Pioneer Elite SC-25 Receiver
CineNova Grande 5 channel Amp
Klipsch KA-1000-THX Sub Amp
(2)Klipsch KW-120-THX Subs
Basement System
SRS-SDA 1.2 upgraded Xover
ADCOM GFA 5500
ADCOM GFA 5503
Yahama P7000S Pro Audio Amp
dbx 120x-ds Sub-harmonic Synthesizer
2-JBL 4645C Subs
1-Paradigm SW2200 Sub
Klipsch Reference in wall's
Post edited by hangon on
    heiney9 Posts: 25,220
    edited April 2008
    edited April 2008
    Hopefully others that have built one will chime in. I think the Stancor is the preferred transformer
    F1nut Posts: 50,820
    edited April 2008
    edited April 2008
    Thanks for clarifying. I had a 50/50 chance of getting it right :).
  • hangon
    hangon Posts: 228
    edited April 2008
    Thank you for the information..I will post the results when I get er done..
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
  • strider
    strider Posts: 2,568
    edited April 2008
    Yep, don't waste your time or money with the Stancor.
    Jesse- is the Avel you listened to in the shoot out thread the same one Scott used to build his AI-1?
    Wristwatch--->Crisco
    F1nut Posts: 50,820
    edited April 2008
    Brock :)
    Ben, No, Rob's was different.
  • dorokusai
    dorokusai Posts: 25,577
    edited April 2008
    I tried to upgrade my SDA interconnect with a new transvestite and it turned into a serious problem. My wife is still angry about it.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    I contacted Earthquake, and the individual mono block modules are actually bridged mono block designs. You need to make an A1 to make it happen. Do not tie the grounds together!
    Ben
    F1nut Posts: 50,820
    edited May 2008
    Hmmmm......we seem to have lost a good part of this thread. WTF???
  • dorokusai
    edited May 2008
    Login much?
    edited May 2008
    Yep, there are several other threads with missing posts. Probably due to the "reconstruction" Justin did earlier. Apparently he was having issues transferring the most current data over after he did whatever magic he does.
    F1nut Posts: 50,820
    edited May 2008
    dorokusai wrote: »
    Login much?
    Could you possibly be more vague?
    F1nut Posts: 50,820
    edited May 2008
    Thank you H9.
  • dorokusai
    edited May 2008
    heiney9 wrote: »
    Just blame it on the moderators, it's easier to do.
    edited May 2008
    dorokusai wrote: »
    No blame, just telling him how it happened :). Something weighing on your mind.
