Polk DSW Pro 400 or HSU VTF-1 on a budget
I've just purchased RTi A7s, a CSi A4, and RTi A1s. Considering I started out with a budget and considering Monitors, I am way over budget.
I've read good things about the HSU but it's out of my price range of $200 - $300. HSU is $399 + $33 shipping ($432)
I've found a DSW Pro 400 for $339 with free shipping and heard that the DSW Pro series is pretty good as well. For someone who has never had a HT or a quality audio system, would this be my best bang for the buck?
I've found some PSW125s, PSW111s, and PSW303s ranging from $186 to $299 including shipping however no one seems to be overly excited about these subs.
Are there any other subs I should consider?
Post edited by dmbrown26 on
  • sheld
    sheld Posts: 5
    edited April 2008
    I cannot spaek to the 400 model, but I do own a pair of the DSW 500's.
    I am very pleased with them both musically and for my home theater.
    They hit pretty low with no distortion, the remote makes it easy to adjust volume and calibrate to your specific placement. I looked at the psw 505 as well, but the digital subs definately outperform them. Hsu and SVS are great subs as well, but I was able to listen and compare the Polk's to other subs in person.
    For waht it is worth, I am pleased my my DSW's and I think you will enjoy the 400 series as well.
    Receiver- Onkyo TX-SR875
    Front- Polk Audio RTI8
    Center- Polk Audio CS2
    Surround- Polk Audio FXi A4
    Rears - Polk Audio T15
    Sub- Dual Polk Audio DSW500s
    T.V.- 50" Samsung Plasma
    Blu-Ray- 160 GB PS3
    Toshiba HD-DVD A3
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    Great comments Sheld, thanks for posting them :)
    The PSW is an entry level subwoofer series and there's not alot of love for entry level these days. The DSW would fit your bill perfectly. It's a great series and much improved over the Polk subwoofers of yesteryear.
  • devani
    devani Posts: 1,497
    edited April 2008
    dmbrown26 wrote: »
    there's good reason for it...polk subs have improved in quality but hsu and SVS are internet direct company and there's less overhead... so you will get your money worth with Hsu and SVS...
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • JoshParsons84
    JoshParsons84 Posts: 565
    edited May 2008
    Hey what about an SVS PB13-Ultra VS a Polk DSW MicroPRO 4000?
  • dorokusai
    edited May 2008
    Seriously? It's a great new line but that's essentially crazy talk.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2008
    Not if he's musically inclined.
