Capacitor Question
andrewc58
I have a capacitor and i have a question about installation. I was wondering if you can use the same ground point as the amplifier for the capacitor. Therefore you would have a ground wire from the amp and cap going to the same ground point. Is this possible without problems?
Post edited by andrewc58 on
Yes, it's the correct way to do it.
You want the cap as close to the amp as possible, hopefully sharing the same wires. -
my question to you is do you need a capacitor, I will be running three alpine type r 12 inch dvc subs rated at 500watts rms, powered by three polk pa series amps plus polk/momo components in the front (possibly bi-amped) and i wont be running a capacitor. From what people here tell me you just need a good alternator and a good battery.tyler birch
ht system
denon avr-1907
monitor 70 towers-polkaudio
nakamichi bx -100 tape deck
sony 5 disc cd/dvd player hdmi ready
velodyne dps-12 subwoofer
Car audio
AMP: FUSION EN-AM8001 800 watts max 368 watts rms x 1 channel @ 2 ohms stable
SUB: 12 INCH 1000W DVC VOLFENHAG 2 Ohm stable useable ohms 2-8ohms -
i drive a crown vic i know ill need a new battery probably will be a optima battery, but i believe my alternator is good for now if i run into problems then i will upgrade it.tyler birch
ht system
denon avr-1907
Car audio
