Would you go for HK avr 525???
Parachoute
Parachoute Posts: 88
edited May 2008 in Speakers
Hi,
This is what I got:
Rti10
Csi3
Fxi3
Yamaha (45wpc) without pre-amp output
I have the chance to grab a Harman Kardon avr 525 for 400$ (I am in Canada).
Would you jump on it?
I am 75% music (usually from my i-pod) and 25% HT and don’t need HDMI for now…
Thanks for any advice
Post edited by Parachoute on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2008
    I'm not sure how prices translate up there, that's a bit steep for a price in the US though. I'd say $300 down here would be about right, so you can do the math.
    That aside, I owned one of these for a while, and it's a damn fine receiver. It'll easily drive that setup to full potential. I believe that's also the first HK stuff with the EZ Set mic built into the remote, and that works fairly well, but not quite as good as a spl meter.
  • strider
    strider Posts: 2,568
    edited April 2008
    I've had that same receiver for a few years and it's done me well. It's run 4 RT55's and a CS400 at a time without really breaking a sweat, as well as 6ohm nominal SDA's. Right now I'm using it as a pre/pro. I do agree with Polkmaniac, that price does seem pretty steep. Have you looked at Harman Kardan's site at their refurbed units? Usually have a lot of different models at good prices.
    Wristwatch--->Crisco
  • Ern Dog
    Ern Dog Posts: 2,237
    edited April 2008
    The price does seem a tad high. The HK is a solid performer with a high current amp section. I had the HK635 drive my Rti10's with ease. They are a good match because my ears found the HK to sound warm and the Rti's to sound bright. Plus you gotta love that blue light in the volume knob. :)
  • Parachoute
    edited April 2008
    Thanks guys, I will check price from Harman Kardon's web site for a refurbished units or offer 300$ for this avr 525. I think this unit could improve my set up and that I could live a year or two with 85 HK wpc and add a separate amp later.
    Another quick and dumb hdmi question: If I buy HD TV, can I send the video signal from, let's say a ps3 or other hd player, directly to the tv through hdmi cable and the audio signal to the avr 525 through rca cable?
  • devani
    devani Posts: 1,497
    edited April 2008
    yes...I have my 445 set up like that...I saw new AVR347 at clearance at Bestbuy in NJ for $350...
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • Parachoute
    edited April 2008
    Thanks for providing an answer devani!
    Just to let you know: here, in Canada, avr347 at clearance is 700$+tx!; Regular price: 900$+tx=1035$!!! So could you buy it in NJ and ship it here!!!!!!!
  • Monster Jam
    Monster Jam Posts: 919
    edited May 2008
    I push 4 LSi15s and an LSiC with the 525. Its getting a work out as I type this, as a matter of fact.
    I've had some reliability issues with the pair I have owned; the one I have is a replacement for the first one that H/K never could fix right. The new one has a failed internal battery which results in me taking about 10 minutes to reprogram after a power outage. Reliability issues not withstanding, its performed flawlessly and beautifully I might add. I'm just waiting for it to die so I can drop the cash on seperates.
    Do you hear that buzzing noise? :confused:
